Ridge Runner wrote:I'm equally interested in this question, sent out a few email inquiries but no replies yet.senior wrote:Next question would be, why wouldn't you put them on top & bottom of stab??
Ridge Runner wrote:Seems odd that a horizontal stabilizer that is equally flat on both sides (that doesn't create lift due to the shape of the airfoil), like on a Kitfox, Rans S6 or RR, would be affected by a VG at all.
is in the down position, it is actually lifting the tail due to the positive pressure from air flowing under the stab & pushing it up. It then makes sense that if you make the air stick to the top of the elevator as it leaves the stab it would create lift.senior wrote:Correct me if my line of thinkin is wrong. EG. when stabilier is in the down position, it is actually lifting the tail due to the positive pressure from air flowing under the stab & pushing it up. It then makes sense that if you make the air stick to the top of the elevator as it leaves the stab it would create lift.
image of the RR with flat horizontal stabilizer, it's kinda small and thin, hard to see I guessUsers browsing this forum: No registered users and 4 guests
