Recently while flying at 7,500 at 21 sq at 11 gallons per hr a vibration came into the control column and was noticeable looking out at the cowl, the edges of the oil filler flap were a bit blurred.
I had flown up to an airport at 3,900 ft above sea level my strip is at 30ft, and had not noticed any vibration in the yolk on the way up.
I have had a bit of a problem with a plug at mag check, the left mag seems to drop 180rpm the right only around 80. I was taught to increase revs to 2000rpm and lean until an rpm drop to clean up any fowled plugs, then enrich to normal operating setting.
As I started to descend to a local strip which is at sea level, and in the circuit the problem disappeared. Again on mag check I seemed to have a fowled plug so went through the routine, on takeoff and the trip to my home strip no vibration.
Could a fowled plug cause this vibration to occur? Or could it be something a bit nastier?
Engine is a Lyc IO540
Thanks for any ideas, John
](/phpbb3/images/smilies/eusa_wall.gif)
