Hi, looking for a little troubleshooting help, our mechanic is a little stumped. We have a Cherokee 180, and have a strong vibration above 2300 rpm, with it being the worst at about 24-2500. Our mechanic is pulling his hair out, they can't seem to find the cause. The compression checks out fine, they removed 3 of the 4 cylinders and the cam seems fine. It doesn't have any intake leaks, and the ignition leads and plugs are good. He sent us to another mechanic to balance the prop, but he felt the vibration was a combustion problem(just like our guy thought), not a prop balance issue. He did some troubleshooting, and was not able to come up with anything other than the baffle in the rear muffler was broken out(gone, not rattling around) and checked with a few sources and they didn't feel like that would be the problem.
We ran up the plane for about a minute and pulled the cowl to check cylinder temps with a laser gun, and all the cylinders were about the same, with the only difference being the #4 exhaust pipe was about 100 degrees cooler than the other three (400 compared to 500)
Any thoughts?
Is it possible to have a valve stick at rpm that wouldn't show up easily?
Thanks, Lance
