Sorry if this has been posted here before. Video is a good reminder for pilots as we have been discussing wake turbulence.
contactflying wrote:I am confused about a couple of things. Were they talking about the first airplane, a low wing, or the second airplane, a high wing? Full aileron, shown in the circle on the high wing airplane, is not what is critical. He needed to be standing on the left rudder, not shown in a circle but clearly not enough rudder used. This is a case where the old guys would say, "his down wing aileron went out." Full aileron without full rudder just aggravated the problem. Adverse yaw pulled the right wing back and very possibly stalled it. Unable to see the aileron or rudder in the low wing.
Avoidance is so much better than recovery technique, but when in the middle of it (something is hitting the fan) we need to stand on full rudder against the roll same as spin recovery. This is why Dutch Rolls need to be to 45 degree bank left and right in modern airplanes. When maneuvering near the ground, we need to know how to move the controls quickly and properly.
akavidflyer wrote:yall been drinking? The plane that crashed was a low wing. The plane that has the ailerons circled is the same low wing plane.
akavidflyer wrote:yall been drinking? The plane that crashed was a low wing. The plane that has the ailerons circled is the same low wing plane. In the same shot you can also see that he has full left rudder input. The second plane was an AN-2... I guess you could say high wing, but it also has a low wing since its a biplane.. So what are you saying the pilot did wrong other than not wait on the ground another minute or two to let the wake clear ??
akavidflyer wrote:The angle is a bit deceptive, but if you put a straight edge across the top if the rudder in the pic you posted you will see the "vee" and can see there is left rudder input.
Crzyivan13 wrote:Contact and Cam, this one is especially for you. (Rotorheads)
Trimtab wrote:Kudos to Contact and MTV.
My only inclusion / addition ?!? is that a couple of my early instructors, on a windy-gusty day would hold the stick or yoke and make me to put my hands in my lap after turning final and said I had to keep the plane straight and level with my feet. It is amazing when you learn that a good rudder will pick up a wing faster than an aileron during slow final approach speeds. And yes ya got MOVE it.
Trim
