Greg,bigrenna wrote:DP, sorry for not sending you the Aerofloor samples... Just got slammed and spaced.
Here are my thoughts on the Aerofloor DOT for a floor: After 260 hours of flying I still dig it, however... it should be thought of as a "gentelmens" flooring. In other words, if you have tight control over whats back there, rarely have passengers, and are careful, its a great super light interior. My entire floor came in around 3lbs as opposed to the 12 lbs of carpet I removed. It is flexible, cleans very easily, and light. The downside as you noted is that the edges have a tendency to roll up and must be fastened. The material is very strong and wont tear. I have often heard the critique that due to the thinness and lack of padding, there is nothing to protect against beating up the floor. This is a valid critique. Velcro really doesnt work to hold it down, so I used PKs. Pulling it for annual is not a big deal at all.
If I were to work the plane or even have a bunch of passengers, I would go with something a bit more robust... in fact I have been tossing around the idea of going with something a bit more robust, especially after seeing the interior of AK Gregs.
No doubt a good option for some. In my situation I think it would end up holding more mud and dirt than I'd like. If I was doing Aerofloor DOT it might be an interesting way to add heel pad reinforcements.Pusher wrote:Or you could paint all the high traffic floor areas with wing walk anti-slip paint and save even more weight.
