waxing and polish
Any do's and don'ts on buffing up an aged paint job? I do have some flaking in portions, but I want to give it a polish/buff since it is for sale and make it look nicer without taking off the paint. Planning on using a orbital buffer.
Also, anyone ever polish a spinner? I have a new spinner that was not finished.. ready for paint or polish. Found a couple of people to send it out to with 3-4 week turn arounds.. looking for quicker results.
Thanks,
Travis
29singlespeed offline
508
Polished lots of spinners, start with sandpaper and sand out all the spinning marks, perpendicular to the lines, then move to a finer paper to remove those lines, then finer again, then polish on a bench grinder with polishing compound and a buffing wheel. Work easy, so as to not build up heat.
It's all finished in less than a day.
Polishing the plane is best done with an air polisher and Mcguiers #1 polish. Works great, and can even be used on lightly crazed plexiglass
side slip offline
61
side slip wrote:Polished lots of spinners, start with sandpaper and sand out all the spinning marks, perpendicular to the lines, then move to a finer paper to remove those lines, then finer again, then polish on a bench grinder with polishing compound and a buffing wheel. Work easy, so as to not build up heat.
Thanks!
508
