used an old tail section of a wrecked plane, he poured lead in the tail and used the tie down ring to attach it.
That was my advice to you on a different forum. That method allows the lead to slide to the very back of the tail cone directly under the horizontal angles, then with a lengthen tie down bolt through this mass, it is secure. The amount of weight depends on what you need. 15 pounds worked for me on three different airplanes, 170B, and two 175 tail wheel.
To those of you who are happy that you can still land with power holding the nose wheel off, what are you going to do when you have to make an emergency landing in rough ground without power? Why fly an airplane that will not glide and flair to a slow landing and is not in center of gravity. With weight in the tail cone, it is just barely in forward CG, however, I had removed the back seat and carried around 200 lbs of camping gear in that area, using F. Atlee Dodge jump seats folded against the wall. The plane flew extremely well with that loading. All gear in the back was secured by a cargo net, including my Dahon folding bike.
The Sportsman STOL leading edge is the best of the group that I have found. I have thousands of hours flying with a Horton cuff, which is a good cuff as well, but Sportsman wasn’t out back in those days (70s). I had Micro vgs on my last 175 in addition to the Sportsman, but could not see any change except that it made me feel better about keeping flow over the ailerons and rudder.
Benefits of STOL are not accumulative with each new STC you install. You need to talk to Micro Aero about removing VGs.
Karl
