EZFlap wrote:If he had cracked rings, wouldn't that also create some other obvious telltale signs... blowing oil out the breather, differences in CHT and EGT on that cylinder, fouled plugs, etc. etc. ?
Hammer wrote:After shutdown, if you stick a thermometer in the oil pan does that temp match what your panel mounted gage tells you?
I think the real question is whether the oil is really that hot, or if the reading is faulty. I'd install a second oil temp gage and compare the two, if that's an option.
good luck!
mtv wrote:My engine ran fine, about the only indication there was anything out of whack was high oil temps, and this was in Alaska. After the engine was overhauled it became apparent the engine wasn't making much power before, but that's hard to evaluate without a before and after.
There may have been some excess oil out the breather, but that too is all relative, and mine wasn't "excessive" prior to overhaul.
Frankly, I doubt this is what's going on here, but an automotive compression tester is relatively cheap, and can be a handy diagnostic tool. Frankly, based on my experience, I don't pay any attention to differential compression....it can be pretty misleading for diagnosing problems....like most stuff, it's just another indicator.
CamTom12 wrote:Well, I fell way behind on the suggestions everyone gave me here. I still have yet to do an automotive compression test, but I'm going to knock that out after work on wednesday.
Today I had some time at the hangar and some help from a friend, so I fabbed up a new cowl exit to see if I could help in the airflow department in case that was the problem. I went down this path because many folks have suggested that my cowl exit area wasn't large enough to vacate the lower cowl area and that airflow was likely my problem.
Here's how the plane came:
And here's what I made:
The before/after was change in ~0.35 inH20 difference between each side of the baffles. This had a measurable difference in temps, at ~10-15 deg across the board for CHT and oil temp. Without had CHTs between 320-350 and OT of 195, with the mod had CHTs between 305-335 and OT of 185.
Both scenarios flown at 135 mph, 2400 RPM, leaned for cruise, 65 deg F OAT, and a difference (high pressure to low pressure sides of the baffles) of 3.85 inH2O before and 4.2 inH2O after the mod.
Even though improving the air flow improved the cooling, I shouldn't be hanging near 185-195 deg F oil temps in these conditions. Especially while CHTs are so close to 300 deg in 65 deg F OATs. Back to troubleshooting the oil system. Next step is an automotive compression test (I have the tool). Pending the good results of that I'll be due an oil change, so I'm going to get new hoses, send my oil cooler off for a flush, and send my oil filter adapter to somebody to check the vernatherm seat.
More to follow!
mtv wrote:I'm glad you at least used color coordinated duct tape on that addition.....![]()
Hope that does the trick.....looks pretty good.
A1Skinner wrote:Is your engine stock or does it have higher compressions? If it has higher comps, your CHTs will run cooler then stock. This is because it's more efficient.
CamTom12 wrote:A1Skinner wrote:Is your engine stock or does it have higher compressions? If it has higher comps, your CHTs will run cooler then stock. This is because it's more efficient.
It's got lycoming 160hp pistons in there. CHTs used to mirror other O-320-160s I know about, only with higher oil temps than them. Now after a ton of cowling/baffle work, I have much cooler CHTs and still warmer oil temps than the other O-320-160s that I know of. We'll see how it all works out this summer... Fingers crossed for reasonable oil temperatures!
On a side note, I recently heard of putting O-360 pistons in an O-320, I guess it gives ~175hp or so? I'd never heard of that before, but someone got it STC'd on Mooney 201s apparently. Kind of a neat idea.
Railchummer wrote:I wouldn't have a warm fuzzy about a cowling mod solving the problem. If oil temps were steady good, then shifted to steady high, something changed with the engine. Operating the engine with oil temps in the upper end of the arc isn't a problem if you know the reason for it; high ambient temps, extended operation at high weights, etc.. But a shift in normal operating temps without a corresponding change in known operating conditions is a warning flag. Something not talked about much in this thread is your oil pressure relief valve or the filter bypass valve. I'm not familiar with your oil system schematic but I'd look at the oil pressure relief valve if it's located so that it can bypass the oil cooler, or the filter bypass valve as well. You had mentioned high oil temps & a 20 psi pressure drop; a pressure relief or bypass valve stuck open (or a weak spring) will do that for you.
When you're doing a standard compression check on your motor listen to where the air's going. If you hear air coming from your exhaust stack you've got an exhaust valve problem, from the carb is your intake valves, and if you have air going through the breather time to check your rings and pistons. But if the engine isn't blowing oil out the breather or burning it (your plugs weren't oil fouled) I'd suspect a relief or bypass valve. It sounds like you've looked at everything else.
