Backcountry Pilot • What is an 8042 seaplane prop worth?
30 posts • Page 1 of 2 • 1, 2
I'm looking at buying a used 8042 prop for my 170 but I don't want to over pay. The prop is currently being stored at a prop shop, it has a little over 200 hours since new and appears to be in good shape. The owner reported it as being smooth running and no rock chips or dings anywhere on the prop. What do you think is a fair price?
Re: What is an 8042 seaplane prop worth?
How much are they asking for it?
907Pilot offline
2500
Don't want to overpay? We are talking about aviation, right? :mrgreen:
In my experience in Alaska, used 8042's are rare. You see plenty of 7653's that people have removed, but not many of the in-demand 8042's. I would not hold out hope to get one much below the cost of new. Especially one in good shape.
Still worth it, IMO.
-DP
DenaliPilot -
Do you run an 8042 on yours then?
I have the aforementioned 7653 on my plane, and this is something I have thought about upgrading for a bit now.
$2000 to $3000 is in line with what I have been told the cost would be
Matt
907Pilot offline
Alright, I pulled the trigger... I'm just gonna get it. I would like to get a better price but I don't see it happening. If I don't like it sounds like I could just sell it to 907pilot! :lol:
907Pilot wrote:DenaliPilot -
Matt
Yes, I do. I have some impressions about it that I wrote down. I'll look for a copy and post it here.
Here's my personal $.02 on the 8042, FWIW.
-DP
I'm not the best source for hard numbers on prop performance. The following is mostly just impressions. But here's some background to help decide if my missions and configuration are applicable or not:
It's been four years since I went from the 7653 to the 8042. It's a bit hard to recall the old performance. Also, I went from 8:00s to 8:50s to 26" GYs during that time span (and also run skis in winter), so there were some other things affecting my TAS. And I'm on 180 gear legs, so my AOA is different from factory geometry. I also have an A model engine, with a couple venturis hanging off the side of the cowl slowing me down.
I bought this plane in Maine, and flew it up to Alaska. That was about six years ago. I had 8:00s and the 7653 prop, and I remember getting around 110 to 115 MPH. I mention this because it was the cleanest the airplane ever was, and the most strictly X-C flying I ever did in this plane. For that purpose, the gear and the prop were probably both desirable. (could have run 7:00s, I guess).
Here at home, my flights are more sight-seeing oriented and I care less about speed. I operate off of an 1,800' gravel strip at 1570' elevation. Air temps are sometimes up in the 80s, but today it's 45F, so DA isn't much of a concern. I sometimes go in to tighter places, but mostly around the same elevation and OAT. I'm 165 lbs, and none of my passengers are particularly large.
In the 7653 days, I was very conservative and treated my plane as a 2-place. I practiced fuel management more carefully, and I still used most of the 1,800' getting airborne. Climb was 300 or 400 fpm as I recall.
Currently, I can take two passengers (besides me), I worry less about fuel management, and I can be airborne with a comfortable amount of runway left over. With two souls aboard I can see a climb of 500-600 fpm.
At most I may have sacrificed 15 MPH to do this. If you are truly cruising at 120 MPH, My guess is that
you will still see over 100 MPH TAS.
The O-300A redline is 2700 RPM. With the 7653 prop I seldom got close to redline. With the 8042 prop it is easy to come close, but I think it would be hard to exceed. However, I think you will notice the increased RPMs the first time out with an 8042.
With the longer prop, you will appreciate the taller stance afforded by 180 legs and big tires. Especially if you will be operating on gravel or snow. I'm 5'-10" and I still have plenty of visibility over the nose in a 3-point stance.
One more thought is that I bought a new 8042, and replaced a high-time 7653. Some of my performance figures are probably just due to replacing a tired prop with a brand-spanking new one. If you are eyeing a used 8042 prop, you should probably take its condition into account when drawing any conclusions from my experience.
For what it's worth, the 8042 seems to be a very common mod here in Alaska. I've heard that the majority of stock-engine 170s here have it. I'd do it again for sure.
You might just need a new spinner if you go for the 8042. My mechanic found one that was ridiculously expensive. I found another option in Aircraft Spruce or Wag Aero which was fully PMA'd, for half the money.
DenaliPilot
Seems like a good thread to mention that the cost of the MT prop for a 170B/ O-300A is not utterly obscene as I'd previously inferred. More like borderline obscene. Hmm... Used 8042, anyone?
I wasn't aware that they had an STC for an MT propeller on a 170... unless it has an O-360.
Neither was I before speaking with the sales reps in Anchorage this spring. One of them claimed he had the same airplane/engine as you and me, and that he has an MT on it. I've got his card someplace.
Interesting, whats the price?
Best to get ahold of them directly if you can. I don't trust my memory of the cost, only that it wasn't as astronomical as I'd assumed.
I'll PM you the guy's info if I can find his card. He was one of two MT sales reps at the Alaska Airmen's show in Anchorage this past May.
robw56 wrote:I wasn't aware that they had an STC for an MT propeller on a 170... unless it has an O-360.
I suspect it's not a STC.
When I had my PA-11, I became familiar with the TCDS for that aircraft. It allows for a wood prop, up to 78" in diameter if I recall correctly. It made no mention of a manufacturer, only wood, thus making the MT legal as it is wood. Although I haven't looked, I'd wager there's something along the same lines in the TCDS for the C170. They left a lot of gray areas in places when those old airplanes were certified.
The price on the fixed MT was within a couple of hundred bucks of a fixed Sensenich for the PA-11. I didn't buy the MT only because I found out about it after I bought a brand - new McCauley.
The Flight Resource guys that sell MT are very helpful. Also, I believe that Dominion in ANC is now a dealer.
gb
gbflyer offline
Any durability issues with the MTs? They were all the rage in the Stearman crowd for a while but guys discovered that they didn't hold up well operating off of turf. Different construction method for this application?
Vick offline
Solum Volamus
Vick wrote:Any durability issues with the MTs? They were all the rage in the Stearman crowd for a while but guys discovered that they didn't hold up well operating off of turf. Different construction method for this application?
That's the one thing I'd be worried about. Anyone out there with an MT prop that can tell us how it holds up to operating out of dirt/gravel strips or off airport?
Rob,
Ditto much of what DenaliPilot shared. I have a '52 170b with the 8242, O-300-D (so vacuum pump instead of venturi), Sportsman STOL, 180 gear legs, steel axles, and 8.50x10 mains with tundra tailwheel. In cruise I see about 95 to 100 mph at 2450 to 2500 rpm. She is definitely not a speed demon but gets off the ground. My personal minimum for off-airport operations is about 1000 feet with 1 passenger, full fuel and a little gear. A good example is Bold Airstrip, which is north of Anchorage at 1,000 feet long, 900 feet elevation, and a bit rough. Density altitude is rarely an issue for me becuase most landings are relatively low altitude, humidity is usually low, and temperatures are moderate. I also operate on straight skis in the winter (Airglass 2500) and the 8242 prop is a must-have for ski ops but you need the 180 gear legs for prop clearance on skis.
Bill
oops, corredtion, as Rob points out below, the prop is 8042, not 8242.
BeeMan offline
Beeman
Sounds like a nice plane Bill, do you have any pictures? The sportsman stol kit and big tires are on my list of things to do as well. Are you sure your prop is 82'' and not 80''. I haven't heard of anyone running that prop on a 170.
robw56 wrote: Are you sure your prop is 82'' and not 80''. I haven't heard of anyone running that prop on a 170.
I was thinking the same thing. the 82" climb props are used on Super Cubs and are what they usually call Borer props. I was also wondering how one would perform on a 170/172td because i had never seen one on a cessna.
PoorMans180 offline
BTW I think you'll be really happy with this prop Rob, That is if you value takeoff/climb performance over cruise.
PoorMans180 offline
