As noted several dozen times on similar threads there is a HUGE difference between a "crosswind" and a "GUSTY crosswind".
Bob,
My experience in Maules is far less than you, but I've been told by many well experienced Maule drivers to NEVER, EVER three point a Maule. Wheel landings have always worked for me in the M-6 and M-7s.
On the other hand, I totally disagree that one NECESSARILY must fly substantially faster for a wheel landing than for a three point. Remember, a crosswind suggests NO additional speed on final. Only a GUSTY crosswind suggests one should carry some extra speed. And, what is that speed? 1/2 the gust factor, so if you have a 15 knot, gusting to 20 knot wind, you should add 2 1/2 knots to your approach speed. I would suggest that most folks in that much rock and roll are going to have trouble being that precise in their airspeed control. But, the point is, you should NOT be adding buckets of excess speed, because you're just going to have to bleed all that speed off once you're in contact with the runway. And, THAT is the only place you are going to hurt the airplane, so slower is better.
Wheel landings can be flown at virtually the same approach as a three point, but at the touch, the tailwheel should be just an inch or two off the runway, THEN the stick comes forward, and the tail comes up.
On a runway, who cares, really? Off airport, it's all about tailwheel protection (break one in some shithole sometime, and tell me you want to do that again) and seeing over the nose to avoid the big uglies.
On a runway, I use whatever seems to work for ME in THAT airplane. To me, there are no hard and fast rules that apply to all aircraft in this regard. Every airplane is a little different, and most pilots have different skill sets as well.
Comparing DC-3 and Beech 18s to Maules/Cessnas/Cubs is a LITTLE bit of a red herring as well, since neither of those airplanes ( the Doug and Beech) have steerable tailwheels, while the others noted do. WHat applies to an airplane with NO tailwheel steering isn't necessarily applicable to one with a steerable tailwheel.
