Backcountry Pilot • Which primary guages?
6 postsPage 1 of 1
Hey guys. Anyone that is running a CGR-30 or similar engine monitor, I'm curious as to which 5 functions you used for the 5 primaries? Oil temp and pressure are a given, but what did you use for the rest? Voltage? Debating going with one but need to know which one to order.
Thanks
David
Re: Which primary guages?
I have oIl pressure, fuel flow fuel remaining EGT/CHT
Gary
shortfielder offline
So does this mean you have bought another plane?
Steve
steve offline
Aircraft: 1980 Cessna 185F
Havent yet Steve. Dealing on one though. I'll know in a couple days and make an announcement.
Thanks Gary. Thats the kind of info I'm looking for
A1Skinner,
Here's the quick and dirty on mine:
You have to balance what you want to see vs. what's required (primary).
I wanted to keep my oil values together, and my electrical values together.
My main screen displays this:
Fuel pressure is a required instrument on the 170 with a 180 HP conversion (Avcon).
2nd. screen allows for one primary instrument because it will display value on primary screen if it gets out of limits (or something like that). I forget, because all values will flash onto the main screen and remote warning lights when they get out of their limits.
So I put the volt meter there due to it being primary. Then put the amps next to it. After the primary ones were placed, I just started putting others where I felt they were the most handy.
I left the Cessna vac/suc gauge on the panel so I didn't have to have this one taking up a primary spot.
Here's the 2nd. screen:
3rd. screen. I did not do the fuel gauges again because I did not want to take up a prime spot with gas gauges, so I left the Cessna gauges on the panel (my 170 has a Skyhawk panel in it, so my fuel gauges are not in the wing root anymore).
As far as I know, w/o having the fuel gauges here, this page is only good for adding in your fuel.
3rd. screen:
4th. screen shows the fuel flow. I left my JPI 450 in and just spliced into its FF transducer for the CGR 30, that way I don't have to skip through the screens to see my FF, its always up on the 450.
Also on this screen is the fuel quantity display, and the switch tanks in....... but I haven't programed that one in yet.
4th. screen:
Also, the EGT/CHT graph area on the gauge does a bunch of different configurations through buttonology?
I could waste a bunch of post pages just showing you, but I haven't even taken pics of all those anyway.
I hope this helps you out.
I know I would have liked to see this during my research phase.
Good luck.
Tom
TomW offline
Tom Weiss perished in a mid-air collision October 12, 2014. He was an enthusiastic and beloved contributor here for close to 10 years, and he will be missed greatly.
Hey Tom. Thats awesome! Thanks so much for taking the time to post the pics. I watched the video on there website with all the different cht/egt configurations. I'm just stuck on the primary guages. I like how you kept your values together on the seperate screens. Great idea. Thanks again.
David
6 postsPage 1 of 1
