Backcountry Pilot • 0-300 Propeller info help
4 postsPage 1 of 1
I was not aware this set up existed until I saw an ad for a 172 for sale.
Looking for info regarding 2 position variable pitch prop for O-300.
Info provided:
Per STC SA3-11
McCauley Hub P/N 2B36C7
Blade P/N 78K-2
Any knowledge shared about this set up would be appreciated. Mike
skyward II offline
Re: 0-300 Propeller info help
That prop is item 1(d) on page 8 of the C170 TCDS #A-799:
"*(d) McCauley two-position controllable, hub 2B36C7,
blades78K-2 (Models 170A and 170B landplane and skiplane with C-145-2H engine)
Pitch settings at 30 in. sta.:
low 13°, high 17.5°
Diameter: Not over 76 in., not under 74.5 in.
Item 108 with seaplane lip and Item 402(j) required."
weight 60# at station <39">
I'm surprised that you apparently found an airplane with one installed.
I'd be amazed if you ever found one of those props for sale.
hotrod180 wrote:That prop is item 1(d) on page 8 of the C170 TCDS #A-799:
low 13°, high 17.5°
That’s what I thought as this 172 for sale is the first I’ve heard of it.
I would love to hear about someone’s experience with one.
skyward II offline
A Unicorn, cool
Mapleflt online
4 postsPage 1 of 1
