The problem is not just the engine reliability, it’s the whole system reliability.
If you ran lower compression pistons or turbo normalized it, then okay maybe 200hp is reliable.
But what prop and PSRU combo are you going to trust at those power levels?
Remember, with auto conversions (or sleds) it’s rarely the engine the fails, it’s everything else. PSRU, pumps, fuel system issues, cooling system issues, electrical system issues.
I used to have a 190hp 1000cc big bore arctic cat. The engine had case porting, transfer port porting, aftermarket custom head, pinned and welded crank, rifle bored carbs, pipes, no oil injection, exhaust valves pinned open (not like they did much after the overbore), more timing.
The engine ran good and it was silly fast, the reliability issues were short clutch life, and the flipper on the right side would explode a belt if you weren’t thinking about what you are doing.
Now I have a 150HP stocker. I hold it to the bar all day long and for the most part don’t need to worry about anything blowing up.
I contend that 150 in that airplane is a lot, and not thinking about when your PSRU is going to explode will add some enjoyment to flying.
Schu
