Backcountry Pilot • 170 belly pod?
170 belly pod?
7 postsPage 1 of 1
170 belly pod?
Anyone ever hear of someone putting a bellypod on a 170? I know there is no certified version out there but maybe something that could get a field approval ? I assume a 180 belly pod wouldn't fit.
Scooper offline
Re: 170 belly pod?
A 180 pod would probably fit. On the other hand there is a saying about "just because you can, doesn't mean you should".
It's so incredibly easy to get a 170 over gross with the space already available, no need to add more space AND drag.
AEROPOD offline
Re: 170 belly pod?
AEROPOD wrote:A 180 pod would probably fit. On the other hand there is a saying about "just because you can, doesn't mean you should".
What he ^^ said. Especially a stock 170. If you have a bigger engine, install an extended baggage, and go fly. Pod would be a bad idea, in my opinion.
Re: 170 belly pod?
That's kind of what I was thinking. Thanks guys.
Scooper offline
Re: 170 belly pod?
I went a fair way down this rabbit hole and as MTV has pointed out there isn't any light at the end of it. I reversed, installed an extended baggage and baggage door instead and would advise that you do likewise.
Re: 170 belly pod?
Big motor 170? Absolutely get a belly pod...right after you install Wing-X!
akgreg offline
Aircraft: Yes
Re: 170 belly pod?
akgreg wrote:Big motor 170? Absolutely get a belly pod...right after you install Wing-X!
:D
Hammer offline
7 postsPage 1 of 1
