mtv wrote:Okay, I'll be the turd in the punchbowl, and argue that the B flaps are really, really better than the A model. Also, there are so many mods that are approved on the B but not the A.....and you ARE going to want to mod it. Extended baggage is huge, as an example.....especially winter flying in AK, where you're carrying wing and engine covers, survival gear, etc.
The B flaps make a difference in BOTH landing and takeoff, though theres more difference in landing. But, don't underestimate the effectiveness in takeoff of using those big flaps.
As to cabin heat: On my airplane (a 1952 B model with O-360), we modified the entire heat system. We removed the carburetor heat from the muffler, and installed a "Stack robber" from a mid year Cessna 172. These things provide a source of heat for the carburetor by a "box like" structure that clamps on one of the exhaust pipes coming out of a cylinder. The carb heat hose is connected to that heat source.
Then, you take the half of the muffler that was originally used for carb heat, and route that via a SCAT hose to one of Atlee Dodge's "Heat robbers" or firewall mounted heat manifolds, which are commonly used for rear seat heat on Super Cubs. That valve routes the heat from the muffler shroud through the firewall and into a manifold for heat distribution in the cabin, or dumps the heat over the side when heat isn't called for.
Now, you have TWO sources of heat. Plumb them both into a cross manifold as shown earlier in this thread, and you'll keep your toes warm.
We did all this as a field approval in Fairbanks on my airplane, which is now back in Fairbanks. It was really pretty simple. The heat robber that goes on the stack is a stock 172 part, but the Scout uses a similar item for carb heat as well. So, standard part, used on similar engine. The Atlee Dodge manifold is really straightforward and is used on a bunch of Super Cubs.
I flew that plane in some no shit cold weather and always had plenty of heat.
Get in touch with the guys at Chena Marina Air Service in Fairbanks if you're interested. They did the work, and the plane is parked in front of their place as well.
That’s the best I’ve ever heard for more heat, I’m saving that for sure. Stock 53 heat is ok down to about -10 or so then it’s just cold. I need to do what you did for sure. Greg
