akgreg wrote:170's RULE - skywagons drool.
robw56 wrote:mtv wrote: NOTHING else you'll do to that 170 will increase the angle of attack for takeoff.
Bushwheels will.
8WhiskeyZulu wrote:...the PPonk Kit really helps expand the 170's capabilities.
8WhiskeyZulu wrote:expand the 170's capabilities.
bigrenna wrote:...The Ponk kit...need/avoidance has been a source of debate here for a long time. I put one in my 170 and then the 180, but there are lots of reputable folks have good arguments against. Lots of reading to do on the 170 site also to make up your own mind.
bigrenna wrote:8WhiskeyZulu wrote:...the PPonk Kit really helps expand the 170's capabilities.
Just an FYI... The Ponk kit wont expand the capabilities at all. It is just meant to back-up the "Jesus" bolt, but its need/avoidance has been a source of debate here for a long time. I put one in my 170 and then the 180, but there are lots of reputable folks have good arguments against. Lots of reading to do on the 170 site also to make up your own mind.
mtv wrote:bigrenna wrote:8WhiskeyZulu wrote:...the PPonk Kit really helps expand the 170's capabilities.
Exactly. The question you need to ask yourself before installing the Ponk gear beef up is : How bad am I going to trash this thing in an accident?
The Ponk beef up will help to keep the gear under the airplane in some situations that would rip the gear legs out of a stock gearbox.
BUT, apply just a wee bit more force to that Ponk modified gear, and it too will depart the plane.
The difference is that if you do this with a Ponk equipped gearbox, you'll take out the whole gearbox assembly, whereas a stock gearbox that's had the gear forcibly removed is often fairly easily repaired. I've seen planes that were field repaired and flown home. You won't do that with a Ponk equipped plane that's had the gear ripped out.
So, how bad are you going to crash?
AK Flyster wrote:Thank you for all the replies and things to think about.
My current prop started as a 7652 which was re-pitched to it's current state as 7647 last year by the previous owner for seaplane operations. It seems to get the plane off the ground fairly quickly, but I don't have experience with it to know how much improvement an 8042 would be. Anyone on here make a change from 7647 to 8042 and care to share the change stats?
AK Flyster wrote:....My current prop started as a 7652 which was re-pitched to it's current state as 7647 last year by the previous owner for seaplane operations. It seems to get the plane off the ground fairly quickly,but ...........
