Backcountry Pilot • 206H NLG fork change
11 posts • Page 1 of 1
Our new to us 01 T206H came with wheel pants (which we promptly removed) and partner does NOT want (will not= so no debate) to add an AirGlas front fork. I believe our 206H model was available with std fork (5.00x5 tire) and a larger fork? Does anybody know where I can find out about the larger option NLG fork? I visited the FAA sites but ended up on a snipe hunt. I just want a little larger tire than 5.00x5 for grass landings; no serious off field stuff; have Husky for that.
Thanks for any/all help. Again, I had AirGlas NLG and big tires on 56 182 so no need to convince me of AirGlas improvements.
flyingjack offline
Aircraft: Husky/T206H
Re: 206H NLG fork change
Good question- Earlier 206 show fork options in the IPC so I thought I'd look it up for you real quick but it turns out my Textron subscription doesn't cover the "late model" airplanes, they want a lot of money for those manuals. Did your airplane come with a set of manuals?
If not you could snoop around the office of a real FBO that has the proper parts book and see if there were different forks available there.
Curious why your A&P partner is adverse to the Airglas fork? I've installed several of them and it's a nice upgrade, especially as the STC allows for pretty much any combination of tire sizes the backcountry pilot might desire.
Halestorm offline
Aircraft: C-182E Pponk
Apparently, strut needs to be cut to size and therefore couldn't be put back to stock when we're ready to sell without finding a new strut. I know, making resale an issue now since we just bought this bird is a little frustrating. Other than that, he is the perfect partner. We're still discussing AirGlas; but, I want to find out what the other Cessna fork is all about.
Thanks again.
flyingjack offline
Thanks again.
flyingjack offline
Jack.
There are two fork sizes available for the H model 206. Where youd find one, I'm guessing Cessna would be first.....$$$
I just recall when the 206H came out, they offered two different fork sizes.
Not much help, but I'd call Cessna or a Cessna dealer, maybe they can offer more info.
It’s easy to buy a new strut tube to modify and keep your original tube unmolested with the original fork still installed. In fact I believe Airglas will sell you their fork with a serviceable strut tube already installed. With the price point airplanes like your’s command it’s hard to believe an Airglas nosefork would impact resale value very much.
Obviously it’s a bit of a project to swap out the strut tube in the strut assembly but it’s not rocket surgery. Good opportunity to install a remote strut servicing valve if the airplane doesn’t already have one. Adding nitrogen to the strut in the stock location is best done by a mechanic with small hands, skinny arms, and a positive attitude.
Halestorm offline
Not sure if it's the same p/n but I may be removing the fork off my 206 because I just bought an airglas. It fits a 700 with a little filing of the casting joint.
Why does your partner not want an airglas fork?
CParker offline
Aircraft: 1979 TU206G
CParker wrote:Why does your partner not want an airglas fork?
Posts 3 & 4 address that
Halestorm offline
Halestorm & Mike: thanks for the info; that will get me up and running.
flyingjack offline
OK, with BCP members help, I've found out the HD OEM fork is pn 1243634-1. I've checked two major online salvage yards, Preferred, Yingling etc and found none.
Anybody know of one for sale?
Thanks
flyingjack offline
flyingjack wrote:OK, with BCP members help, I've found out the HD OEM fork is pn 1243634-1. I've checked two major online salvage yards, Preferred, Yingling etc and found none.
Thanks
Sutton Aircraft Salvage, they had everything I was looking for FWF for the 0-360 upgrade on my 170B
Mapleflt online
