StillLearning wrote:anorphirith wrote:Thanks for the feedback.
I would get a 170/180 if I could afford the maintenance.
I think an experimental S7 is more in my budget and skill level.
I’m not sure what is so expensive in maintenance on a 170 or 180 that people can’t afford. Unless you build the s7, and get your repairman certificate, you still have to pay someone else. I own a 180, other than the upgrades I choose to make, the maintenance is pretty minimal. If you lose a cylinder on a 470, or you lose a cylinder on a 360, is the cost really any different? Other than a couple more cylinders and a cs prop, what really is the difference?
You would have to pay someone to do the yearly condition inspection on the S-7, but they only have to hold the A&P license, not necessarily an IA. And as someone else already pointed out, literally anyone can do all the other maintenance on an Experimental, and that includes the owner.
And you're probably correct about Lycoming vs Continental being pretty much a "draw" as far as maintenance costs. But most of the RANS S-7 fleet uses the Rotax 912ULS. The design was optimized for that engine, and a Lyc/Cont on the nose would make for a very unbalanced airplane. And given the Rotax engine, maintenance truly should be considerably lower than for Lyc/Cont... The vast majority of Rotax engines make TBO without ever having a cylinder pulled or having the engine opened up at all. As for "regular" maintenance items: Spark plugs for a Rotax are around $3 each, and can be purchased at your local auto parts store. Oil and filters are significantly less expensive than for a Lyc or Cont. There are no mags to be overhauled every 500 (or less) hours. The carbs can be rebuilt (with readily available kits) by pretty much any competent mechanic. There's even a "Rotax Owners" website you can join ($30/year) that has extensive videos to teach you how to do many of these things for yourself.
