So I've been looking at this aircraft and I've been gathering more informations on it for the past week
https://www.controller.com/listing/for- ... t-aircraft
It's a Rans S7-LS registered 5H-CED currently located in Zanzibar, Tanzania.
It has had a hard landing and both landing gears, the rudder, and tail wheel, and the right wingtip plastic has been changed. The bottom of the tail section fabric also took a hard scape during the hard landing and probably needs to be redone. Along with fabric work in other parts of the plane.
When changing the right landing gear the fuselage has been deformed where the right door doesn't align with the fuselage correctly anymore apparently they had to use a lot of force to remove the bent gear and also to install the new one.
It doesn't have a transponder or a radio nor ads-b.
Finally the engine has been swapped at around 40hours,the Zanzibar dealer used the original engine as a donor for a Rans S6.
So the plane has 127hours but the engine has 91.
I contacted Randy at Rans (an absolute great guy) and asked him what should be done on it. he said that if the door doesn't align it's probably because it had been opened during flight and slammed back deforming it.
But the Zanzibar mechanic assured me that the fuselage was indeed deformed, not the door itself.
I was wondering if the fuselage has been stretched/deformed where the landing gear assembly is, how would it affect the structural integrity and the ability to take hundreds of future backcountry landings?, what do people do in these case? Do they cut the tube and reweld new ones ? push them back into shape ? what other concerns should there be ? I was thinking the wings and their struts must have taken a lot more force that they're designed for as well.
