Backcountry Pilot • Aktahoe - Adventures in a Backcountry Super Cub Rev 2
193 postsPage 9 of 101 ... 6, 7, 8, 9, 10
Re: Aktahoe - Adventures in a Backcountry Super Cub Rev 2
https://youtu.be/JWaZ8FqVh70
aktahoe1 wrote:https://youtu.be/JWaZ8FqVh70
Beautiful.
Crzyivan13 offline
Aircraft: 1957 Cessna 182A
Little one wanted to go fly and swim somewhere. One of the more fun flights I have had.
Checkout the speed were getting with the 35's. All engine temps below 400 now. I have fallen in love all over again.ImageImageImageImageImageImageImageImageImageImageImage
Great video, gorgeous plane.
You have a great life, first and foremost because you clearly recognize you have a great life.
I started to write that saying 'You are a lucky man', but I recognize luck is a very small part of it. Good for you!
albravo offline
Congrats my friend.
Barnstormer offline
Looks so fun! I was really hoping to meet you and see your plane at OSH, but you are clearly right where you should be.
Your airplane is really beautiful and very impressive. Enjoy!
Joe
twflyer offline
Ha! That's a great pic of your kid looking skyward, without any aircraft in the frame. A non pilot wouldn't get it, we do. I get a kick out when a plane flies over head and my dog gives it a careful look, same deal sort of. 8)
Ranch Pilot in his post on July 16th said the 4place will be at Booth 423 at Oshkosk. I have several friends there who stopped by--no 4 place. Is it elsewhere on the field at Oshkosh?
tedwaltman offline
Getting used to the AOA dragging it in at 18-22mph. Low 40's over the water. It's a strange feeling but man is it slow. I know it can go slower. It's just crazy to me.
Full flaps come in once I'm over the shore otherwise it comes straight down. Over the shore it goes full flaps, add power, keep pulling back on stick and hold it off while the speed just continues to drop. At one point I found myself at nearly full power to hold the AOA. My mind has been blown.
AKT
These things work! The plenums are keeping the cylinders in the 380's/390's. Oil change today with 60 hours on the engine.
T3 sure makes a nice ride as do the Shock Monsters with 35's at 2.4 PSI
And we haven't even talked about this yet. The Aero Fab precise flight control stick
FYI, Snap On makes a really nice low pressure tire gauge that I've used now for a year+. Very accurate:
https://store.snapon.com/Dial-Type-Pres ... 47062.aspx
tedwaltman offline
Been flying a lot. Have a lot of video on my YouTube page. Need to tighten my flaps up. The blow back on the big Kellers is somthing else. In each flap setting I'm only getting maybe 1015 degrees of deflection. Still landing at 18-22mph. (Lots of video to confirm that). Can't imagine what this bird will do with the 50 degrees the Kellers promote. Anyhow here are some photos from the past couple days
Looks like you are having a blast with the new plane!...That's awesome!
CFOT offline
Need to do something about my flaps. The Keller Flaps are notorious for poor retraction. Tearing into them now then family vacation for 10 days. Thinking its a bell crank issue but not certain until we get into them. Gonna get a larger flap handle and tighten the cables as well but they already seem tight so we will see. The issue is blow back. On the ground static they are great. Once airborne at 25mph at full deflection they are only showing about 10 degrees or so of flaps deployed. No different that the 1st notch.
Anyhow the brd flies incredibly slow. I cannot imagine how she is going to fly with full flaps as advertised by these big Kellers. Heres a 22mph touchdown with me at 225, my back seat pax at 180, 20g of fuel on board, 8700' DA and 84 degrees hot! Its not as rough as it looks. The camera man had one had on his iPhone. Its uphill and fairly rough but not really. Stable approach at 27-30mph then touch down at 22mph. Look at the tape on a big screen. Its nuts! Steam gage Airspeed does not even register. The speed was also confirmed on my Garmin VIRB. 22mph
Anyhow, here are a few videos
https://www.youtube.com/watch?v=veVPwTasBsM
Flaps on departure on 25mph
https://www.youtube.com/watch?v=dT_uQ3lcMcw
Flaps on the ground static
https://www.youtube.com/watch?v=M3rPZ7jHvag
Some slow landings with very slow touch down speeds. Only 10 degrees flaps (full flaps are pulled but you can see there not all the way out due to blow back) and no brakes on landing. No sense burning up brakes if you don't have to.
https://www.youtube.com/watch?v=a2Gdo8UPCHs
https://www.youtube.com/watch?v=k-jIdIQZnGY
My buddy Kevin Sloane passing in his 2010 SQ at 24mph and my new Rev 2 sitting here on the beach
https://www.youtube.com/watch?v=t9XHb25NAa0
AKT
Kevin, Have you had a video of your flaps from when you go full to touch down?
Also take a of them at full and power up and take off and see what they do as the speed increases?? Might see something to see
Good Luck Sounds like fun!!
M6RV6 offline
I think we need the video of that new bird getting its feet wet across Lake Tahoe..... :evil:
180lamb offline
Awesome bird! Keep the videos coming Kevin.
Waterboy offline
https://youtu.be/g71lnHNTpWg
aktahoe1 wrote:https://youtu.be/g71lnHNTpWg
You need to get some 480/720P back!!
piperpainter offline
Aircraft: C-205
Was Backcountry Mooney M20C
