Backcountry Pilot • Alaska to Alabama, take two
63 postsPage 3 of 41, 2, 3, 4
Re: Alaska to Alabama, take two
Made it!
I'm pooped, yesterday was a long day! I'm going to get started on the write-ups for the last three days.
Some stats:
Fairbanks to Huntsville in 4 days and 26.7 hours.
Day 1, Fairbanks to Tok: 1.6
Day 2, Tok to Ft Nelson: 6.9
Day 3, Ft Nelson to Estevan: 8.7
Day 4, Estevan to Huntsville: 9.7
CamTom12 wrote:Made it!
Some stats:
You wild man! :D. Very impressive!
Some stats:
We clearly used appropriate build-up to the long days, haha.
Glad you made it safe Cameron!
A1Skinner wrote:Glad you made it safe Cameron!
Sorry I missed you, David. I was really looking forward to meeting you!
I'll fly through again at some point when I can make sure I have enough time for shorter legs and side trips. I have your lat/long :D
In the meantime, if you're ever near North Alabama I want to link up!
No worries Cameron. Like I texted, the 17 hrs days of harvest don't allow me to be much of a host. I will hit you up if I'm ever in the area for sure! Only been once, to Talladega for a Nascar race. Would love to go again.
Would love to show you around this area as well!
David
Sorry to hear we missed you in Ft Nelson. We left for the Yukon last weekend. Glad you had safe trip. Catch you next time.
UpNorth
UpNorth offline
UpNorth wrote:Sorry to hear we missed you in Ft Nelson. We left for the Yukon last weekend. Glad you had safe trip. Catch you next time.
UpNorth
No worries, we were only in town for a few hours and spent it with family. Next time!
I bet that it feels good to have the plane home!
Crzyivan13 offline
Aircraft: 1957 Cessna 182A
Crzyivan13 wrote:I bet that it feels good to have the plane home!
:-D
It's just a short hop from Huntsville over to Peachstate Aerodrome (GA2). It's worth a visit .. good food, old airplanes, nice people....
http://www.peachstateaero.com/
kg offline
Aircraft: Cessna 180J
Cam,
I'm really fascinated by that airplane. You've provided some info, but now that you've done the ultimate cross country flight with it (couldn't get a whole lot longer....Pt Lay to Key West, maybe, when you have some time, could you tell us more about the plane?
It's a sweet looking ride, and obviously fast.
I did one 9.1 hour flying day enroute back from OSH this summer in the Cub. Haven't done one of those in a long while, and was actually surprised that I wasn't more stove up. Hotel room, hot shower and a good steak that night in Miles City helped the recovery :lol: . Oh, yeah, and an adult beverage or three.
Tell us more about that beautiful little machine when you're rested up. Looks to me like you scored big time...... =D>
mtv wrote:Cam,
No problem! I'll start off by saying this airplane is much faster than I thought it would be. Roger put a real winner together!
It was formerly a '59 Tripacer that lived in WI, TN, NV before it made its way to AK, where it resided in Tok and then Kenai for a while. Roger bought it in '02 and began the restoration process that ultimately ended with an E-AB certificate.
The major alterations are the RV-6 cowl that required widening and reshaping as well as a hand-fabricated boot cowl, the addition of plexiglass everywhere in the cockpit (to include a full skylight), and the Grove one-piece spring aluminum main gear (gun drilled for the brakes). He also built an all metal interior which is beautiful, and installed Atlee Dodge 30.5 gallon tanks. Everything else is pretty much standard Pacer, though Roger cleaned up the frame to a "like new" condition.
The motor is a wide-deck O-320 with 160 hp pistons, and the prop is a 74 inch Sensenich that was re-pitched to 56 inches. I don't know if it's enough prop as we had to take care not to overspeed the engine, but it swung to 2350 static. I'd love to see what a CS would do. Maybe I'll try one out one day after it's paid off...
We cruised around 2450 to 2500 rpm for most of the trip, and fuel burn was predictably around 9.2 gph. One early leg we flew at 2300-2350 rpm and saw 7.4 gph. Another early leg we flew between 2350 and 2400 rpm and saw 8.4 gph. To lean we just pulled the red knob out until the engine stumbled, then increased until the engine smoothed back out. We then watched the CHTs and richened as necessary to keep below 400 degrees as a max temperature and 380 degrees as a continuous temperature. At 2450-2500 rpm, the Racer indicated 135 to 140 mph at 3-4,000 msl. At the same RPM we saw 120 mph indicated at 9,500 msl.
During climb out in the lower 48 we kept airspeed around 105 to see between 500 and 250 fpm above 5,000 msl. It was necessary to keep the speed so high to keep the oil temps down. I saw 235 degrees during one climb out before we start climbing at much higher airspeeds, trying to keep oil temps lower than 220 degrees.
The only squawks from the trip are the head temperature spread between cylinders and the tach timer broke as it swung over 100 hrs. Right now the plane has 103.6 total time :D.
The airplane is nimble and fun to fly and control forces are very light. It's really hard to slow down to flap speed :D
In all, I'm VERY happy with the airplane. Roger is a craftsman and did an excellent job building the Racer. I need to work on my technique to see how short I can get it off and landed in, but I imagine it'll be very similar to a certified Pacer. Plus I can cruise much faster.
Cam,
I like the wide gear. The only thing I trained students in with a wider gear was a Callair. It was single seat, but a pussycat.
contactflying wrote:Cam,
It's needed. The Racer is squirrely on the ground. You have to stay on your toes. The only other shortwing I've flown (Gilbert Pierce's Clipper) was docile compared to this. I've heard theories that it's due to the stiff gear. Good news is that the spring aluminum doesn't bounce.
Dynamic, proactive with the rudder pedals. Just like with the anti-torque pedals at hover. That OH-58 was squirrely too. Apparent brisk walk rate of closure approach keeps power on to touchdown. That prop blast on the rudder helps. Power also lets you cushion it on.
Unless they have changed the engine, use the expensive Shell oil with the additive for the 160 hp 0-320. On the pipeline we had valve trouble with that engine in C-172s until that service bulletin came out for the additive. Never had the problem with the 150 hp engines with any brand of oil.
I forgot about the windows in the bottom of your airplane. You can't look through the chin bubble on short final, like a helicopter. When the numbers go under the cowl, look on down the runway for the apparent rate of closure.
contactflying wrote:Dynamic, proactive with the rudder pedals. Just like with the anti-torque pedals at hover. That OH-58 was squirrely too. Apparent brisk walk rate of closure approach keeps power on to touchdown. That prop blast on the rudder helps. Power also lets you cushion it on.
True, that's exactly what it feels like - hovering a 58A/C.
Don't worry about the chin bubbles, I'm looking out the windscreen on final until all three wheels are down.
I'm undecided what this airplane likes better, wheel landings or 3-points. I'll just keep practicing both until I figure it out, then I'll practice the harder one more :D
CamTom12 wrote:
mtv wrote:Cam,
He also put fairings on just about every place you can. Flap and aileron hangers etc. You have one sweet bird, I've lusted over it more than once at his hangar but I couldn't see myself taking that plane and beating it around the brush hunting with it.
akavidflyer offline
Can,
I'd put the plane on grease plates, and check the gear alignment. Are the axles shimmed so you can adjust them? May be the gear isn't quite tracking right. Lots of Cessna taildraggers need gear alignment.
