Backcountry Pilot • Alaska VFR minimums
Alaska VFR minimums
25 posts • Page 2 of 2 • 1, 2
Re: Flying Wild Alaska
GumpAir wrote:Under Part 135.205. The real-life translation is 1000 ft/1 mile, 500 ft/2 mile to DEPART on a Special VFR or flying in uncontrolled airspace.
Sec. 135.205 — VFR: Visibility requirements.
(a) No person may operate an airplane under VFR in uncontrolled airspace when the ceiling is less than 1,000 feet unless flight visibility is at least 2 miles.
(b) No person may operate a helicopter under VFR in Class G airspace at an altitude of 1,200 feet or less above the surface or within the lateral boundaries of the surface areas of Class B, Class C, Class D, or Class E airspace designated for an airport unless the visibility is at least—
(1) During the day—1/2mile; or
(2) At night—1 mile.
Coming home is a whole other story, at least it was in the old days, and all that is required is "one mile" on the visibility. Ceiling didn't matter. 100 and one got you home, and if you were iced up and running out of options fast, FSS always found "one mile" just long enough to get you back in. Then things snapped shut once you had landed.
And if anybody goes up there to fly for a living and thinks VFR means VFR, boy do they have a surprise coming!!!!!
Regarding part 135 and special VFR:
Can't find it in the regs regarding 500 and two or 1000 and one
In fact, 91.157 states special VFR is only if the flight is conducted part 91?
Anyone able to shed insight on how they get it done legally? Part 135 specifically
Thanks
Matt
Matt 7GCBC offline
Re: Alaska VFR minimums
Part 91 applies to almost everything, see 91.1 (applicability).
In addition, part 135 applies to many commercial operators, see 135.1 (applicability).
In general, part 135 adds restrictions or requirements to part 91. Both must be complied with. But a part 135 operator cannot comply with part 91 in a manner that violates part 135.
Troy Hamon offline
Aircraft: Piper PA-22
Matt 7GCBC wrote:Regarding part 135 and special VFR:
Thanks
Matt
Part 91 is if ground visibility is less than 1 mile but flight visibility is a mile.
If ground visibility is a mile then 135 is good to go! :D
TangoFox offline
Keep the Greasy side down!
It's right there in the few lines of 135.205.
Special VFR lets you fly in controlled airspace at uncontrolled airspace visibility minimums.
1000 ft ceiling, you need only one mile vis (that sucks pond water), or below 1000 foot ceiling, and Part 135 you're not gonna legally fly below 500 ft AGL, it's a 2 mile requirement on the vis (much better than one mile, or less :roll: ).
Alaskan's get a jump start on being old farts.... even when young.
Just ask Gump.
We used to "gather round" in the fog... and have one elected guy ask for the special. Then we all quietly followed him in.
FSS knew what was going on. The deal is... noboby drives. So, if you are not willing to figure out a way to get places...for other pilots, then on the days you have places to go... in ain't gonna work very well for you. Unless you had a cumfy boat to get around on....
flightlogic offline
