Cary wrote:You will have more power in your airplane than the Bearhawk you flew at Big Piney, but your extra power won't make much difference in how far you roll before lift off, although it will make a difference in your climb rate.
Why?
Zenithguy, I'm not sure if you trying to discourage or encourage me to do it...That's a pretty rough crowd your hangin out withI'd say your living the dream.
CamTom12 wrote:Cary wrote:You will have more power in your airplane than the Bearhawk you flew at Big Piney, but your extra power won't make much difference in how far you roll before lift off, although it will make a difference in your climb rate.
Why?
Cary wrote:CamTom12 wrote:Cary wrote:You will have more power in your airplane than the Bearhawk you flew at Big Piney, but your extra power won't make much difference in how far you roll before lift off, although it will make a difference in your climb rate.
Why?
Just my observation flying virtually identical airframes with different size engines. I've never flown a Bearhawk, but I've flown 172s with 145hp, 150hp, 160hp, 180hp, 195hp, and 210hp engines. While there's a noticeable difference in where a 145hp 172 and a 210hp XP breaks ground (partly enhanced by the CS prop on the XP), there's very little difference between where 180hp 172 with a CS prop and a 210hp XP breaks ground. The XP definitely climbs better, though.
Whee's planning a 210hp engine in his Bearhawk, and he's flown a 180hp Bearhawk. Everything else being equal, the biggest benefit to a little more horsepower that I think he'll experience is increased climb rate, not so much a significantly shorter take off ground roll.
corefile wrote:It also looks like if you ran the strip more corner to corner (remove those trees) you could probably pick up another couple hundred feet. You would be looking at something in the range of 900-950 ft - and at that point you are pretty much good to go.
goldfinch wrote:Someone is growing a crop on that field and the rest of it towards the main road. Let them farm the triangle in trade for letting the center strip be used to takeoff and land. That'll give 14-15 hundred ft., just can't use all of it taking off towards the power line. Farming and flying can live together. Lets make a deal.
hardtailjohn wrote:I fenced mine off Whee, for when I need it, but it's grass, so the horses go on the runway for "ground maintenance" quite often...it helps keep all aspects happy. When they're out of the runway, they don't even look up anymore..even with a noisy 185 or Beaver...they just put their ears back.
Battson wrote:The thing is...
There is a big difference between landing at a 300ft gravel bar one time when you go fair-weather flying, and wanting to get back to your home hanger every time you fly. At the end of a long day with a load aboard, possibly with undesirable crosswinds or high DA, it starts to become a dangerous proposition.
It seems small for a landing in anything other than suitable weather or with a light loading. You could keep your plane there, but you might not be able to land back at home on a lot of days. So you would need a back-up place to divert to.
Cary wrote:Of course, if WW (that's Whee's Wife) wants horses, pretty soon the idea of a runway will be moot, because the Bearhawk will have to be sold to pay for maintaining the horses. Both are pretty darned expensive hobbies
