I did a reverse approach: found the property first, then built the strip and then tried landing with a few STOL planes. I ended up buying an Aeroprakt/Foxbat A22. Attached a video of the first landing...
Statler wrote:I did a reverse approach: found the property first, then built the strip and then tried landing with a few STOL planes. I ended up buying an Aeroprakt/Foxbat A22. Attached a video of the first landing...
hotrod180 wrote:IMHO the danger with using an "everything-just-right" strip for your home base
is that you will be tempted to use it even when the conditions do not warrant that use
