Anyone have any experience with this product? Would be a nice addition to the junk I haul when camping.
http://www.twistedthrottle.com/antigrav ... wer-supply
svanarts wrote:Anyone have any experience with this product? Would be a nice addition to the junk I haul when camping.
courierguy wrote:
17 lbs.?! What brand is that gen set? I thought the Yamaha was the lightest, at 27 lbs (a couple lbs. less then the littlest Honda) I could use something like that for pre-heating in the winter, and only need 200 watts capacity total, so have been looking for the smallest one possible.
svanarts wrote:Well I bought an antigravity battery. I'll report back when I get it.
bumper wrote:Checked their website - not much info on the actual specs (voltage, amp hour capacity, etc.). One may assume that it is a 4 cell lithium ion battery pack with a DC to DC converter for the USB 5 volts. Doubtless there's also a BMS (battery management system) to prevent overcharge or discharge.
Bottom line, you can buy a lot of lithium battery for a lot less money. Also, LiFePO4 (lithium ferrous phosphate or LFP) battery technology is a lot more stable, and less prone to thermal runaway than the cheaper lithium ion. StarkPower sells LFP starter batteries as well as energy storage batteries (the difference is that starter batteries have typically less capacity but much higher max current capability - this due to construction, more cell spacing for cooling etc). Search on Amazon for StarkPower batteries - there are other good brands too.
If you don't want to cobble together your own, there's this one: http://www.amazon.com/StarkPower-JumpBo ... er+battery
bumper
