I know of a few aftermarket designs which have included slotted or double slotted flaps. This isn't what I am looking for.
For a long time now, I have been toying with some concepts to reduce the nose-high attitude at stall with our Bearhawk, to give better forward visibility during a true max-performance landing. I also want more lift so we can fly slower. The flaps look like the best bet here - benefits are ripe for the picking, and changing the flaps isn't a colossal modification. The Bearhawk flaps are honestly 'bolt on'.
Looking at some data sourced from an old Naval Aviation book, I found the following data which suggests that fowler flaps are greatly superior to both slotted and plain flaps in terms of reducing the AoA at stall, and for increasing the lift too. Apparently a win-win. They basically redouble the same benefit over again, compared to no flaps (basic section).
Before I go any further with my hair-brained investigations, like starting an engineering design and dragging up my old university texts, I wanted to see if any other light aircraft use this kind of flap. Anyone know of any??
Obviously it's not all goodness and sunshine, otherwise more aircraft would be using them. I am guessing weight of the rails, complexity, and extra drag would be some of the main issues.
But.... an extra 35% lift and 4 degrees lower nose attitude sounds pretty darn good!
If I can shave off just 4 kts at the stall, I would be landing at a cub-like airspeed... and cruising at 130KTAS... so in my head it's worth investigating at least a little bit.
Thanks very much for the intel!
