Backcountry Pilot • Aux Fuel
Aux Fuel
24 postsPage 2 of 21, 2
Re: Aux Fuel
bat443 wrote:...I don't doubt that your 170B had tanks with two fuel pickups each but I just reviewed the 170B parts manual and that is not how they left the factory. Each tank had one pickup just aft of the fuel gauge and the line runs aft and down the door post....
That's how I remember it from my 170 days also.
My ragwing had a single outlet, and the fuel lines ran down the forward door posts.
That turned out to be problematic, leading to an engine-driven fuel pump being installed,
so Cessna rerouted the lines down the aft door post in the A & B models but stayed with the single outlet.
Re: Aux Fuel
hotrod180 wrote:
mtv wrote:….. If the photo is of your floats, they’re EDO 2000, so small hatches if you have hatches, but install some anyway to keep CG forward. Aft CG isnt going to be your friend in a 170 on EDOs....
"So small hatches".....how small are these small hatches?
Big enough for a standard 5 gallon gas can,
or would it be a bushbag or smaller cans show?
I can’t cite the dimensions, but the openings are narrow, maybe eight or nine inches. Standard five gallon cans don’t fit.
Re: Aux Fuel
Interesting discussion about usable fuel, etc. My P172D's manual says I have 52 gallon tanks with 42 usable in all configurations, but the manual doesn't say anything about more in straight and level. Flint says, however, that the P172D has 47 usable when flying straight and level. Personally, I prefer not to stretch things. Although I can recall one flight in which the refill took 40.0 gallons, the most I've put in in years has been 37.2, usually right around 37 when I've pushed it a little. That leaves me with about half an hour's usable in all configurations. It also coincides with my usual bladder needs! :shock:
I have given some occasional thought to Flints, as I've mentioned. But every time I give it some thought, I decide I'd rather spend the money elsewhere. I just don't have a need for more fuel, just an occasional want. They do look like the best alternative if I did have a need.
Re: Aux Fuel
I've decided that for my "occasional" aux fuel needs float lockers will work nicely and be functional and offer larger applications as well
