daedaluscan wrote:I think Stoots have an STC for that 80” on a 170. Not sure about 175.
daedaluscan wrote:It was the weight that put me off. Just put a 76" on and I'm heavy already. Guess I need more AMUs for a composite prop.
Mapleflt wrote:daedaluscan wrote:It was the weight that put me off. Just put a 76" on and I'm heavy already. Guess I need more AMUs for a composite prop.
Go on an OM C of A and hang a Catto on the nose, 12 lbs.
john54724 wrote:Flight Resource owns the STC and supplies all the props for all Cessna 170, 172 and 175 models as long as they have ANY version of a Lycoming -360 series engine and hydraulic propeller governor. The STC has two 2-blade versions including the popular Ultra and a 3-blade version.
https://flight-resource.com/stcs-available/
All are in stock for immediate delivery. No RPM range restrictions and only 46 lbs. Money back satisfaction guarantee!
Call me for info.
Thank you,
John Nielsen
mtv wrote:daedaluscan wrote:It was the weight that put me off. Just put a 76" on and I'm heavy already. Guess I need more AMUs for a composite prop.
So, does your plane have an AVCON STC'd engine installation? Because if you do, that STC calls for a maximum propeller length of 74 inches. A friend just had to have his prop cut down from 76 to 74 because of this. Which is right up there with the dumbest thing I've heard of, but that's what the STC calls for.
daedaluscan wrote:mtv wrote:daedaluscan wrote:It was the weight that put me off. Just put a 76" on and I'm heavy already. Guess I need more AMUs for a composite prop.
Pretty sure my STC allows 76 or 76-2. I will check. I found a non AD hub that is zero timed to just under 76” if I remember correctly. I am delighted with the way it pulls, but my CG is forward. Two fatties and low fuel needs aft ballast.
That post above by John is just unkind. I mean money back guarantee. Definitely on the wish list.
daedaluscan wrote:My Delaire STC specifies HC-C2YK-1BF/F7666A or A-2 for the Constant speed, no length limits.
I had assumed it was the same as the AVCON, but maybe not?
