"Bad Habits" of Nose Wheel Pilots
4557
- Aircraft: Old Clunker
It is easier to get laid ( as in doing the actual laying) in a nose dragger.The tailwheel will get you laid more just because of overall coolness .Once the laying has started I would just assume be in a nice roomy 207 . In my experience anyway.
low rider offline
793
vail
err ,, I mean, yea , nosewheel is more forgiving.
low rider offline
793
vail
GumpAir wrote:qmdv wrote:Mud is not fun.
REALLY???????????
There are exceptions to every rule!
172heavy offline
373
172heavy wrote:My IA says that a nose dragger can take off shorter than a tail dragger due to the fact that it can rotate further on takeoff, producing a higher angle of attack, due to the fact that the main gear is further back and a tail wheel cannot rotate any further than it already is.
Put AK Bushwheels on that taildragger and it'll fix that problem right up.
dabridgham offline
23
Fri May 04, 2012 12:46 pm
Bad habits? Flying within a margin for landing that assumes "Ah, I can just add flaps and fix the landing on short final."
On the other hand, if have flaps, you lucky ducks, then how's that a bad habit? I don't just shoot for perfection every time I fly because I'm a perfectionist, but also because I don't want to rebuild my plane again and can't afford to replace her.
Dot_AK offline
113
