Backcountry Pilot • Bearhawks at Llano
Bearhawks at Llano
30 postsPage 2 of 21, 2
Re: Bearhawks at Llano
n144sh wrote:Great video!
I'm also building a Bearhawk 4P from a quick build kit in Sisters OR. I work in Portland though and fly back and forth to Twin Oaks - would love to see your project if you are up for it.
Steve
n144sh RV-4 completed 2001
n144th Bearhawk 4P in process
Sure man. It's at my house though in Lake Oswego. Maybe some time this summer you can swing by for a beer and the project tour.
Cut those leg fairings NOW for the Bushwheels to fit. What you,ve done so far looks top shelf.
Bearhawk Builder offline
Wow! Zane, you've got a great setup, but it's wayyyyy to clean. Can't wait to fly formation with you to Chukar! 8)
scottnt offline
Zane don't forget the float fittings.
46tcrft
46TCRFT offline
Boy O Boy that is one tough inspector you have going over the plane. Does he really think he needs to inspect the flare on the gas lines for being correct. Your in for a tough haul with an inspector like that.
Nice call on the QB kit, we scratch built our Bearhawk. We had just finished ours when the kits came out so QB was not an option. While the Bearhawk is not marketed as a back country plane it is one,bigtime.
Congratulations on starting the journey.
KenW
175 magnum offline
Zane you should have done ... and placed the ... over there. Or moved the ... by the.... position and then your ... isn't quite right either. But I guess some people like to have the ... on the right side instead of the left where the ... can interfere with the ...
(hey, somebody needs to give you some grief. :D )
Bearhawk Builder wrote:Cut those leg fairings NOW for the Bushwheels to fit. What you,ve done so far looks top shelf.
+111111111111
What he said... I suggest doing it NOW... those fairings are the biggest pain, of many pains in my ass at the moment.
Sure you will need to do a little welding (probably) but the job will NEVER be easier than it is right now. P.s. I clamped my fuel selector valve too.
I am in your camp with the kitlog, I ended up so busy building that I never got around to it. Just 3000 photos and a timesheet.
Good video!
Gunny offline
I'm pretty comfortable doing a little cutting and welding. Battson did you just remove part of the fairing per the engineering notice from '09? Curious what the finished solution looks like for covered legs running big tires.
I haven't done it yet - thus the PITA factor. I wish I had done it, when I was at the stage you're at now.
