m_moyle wrote:Question… aren’t external loads loads specifically allowed in Alaska without a field approval? Wouldn’t a cargo pod fall into that category just like a lumber rack… I’m thinking of building one for my PA20 using the original rear gear leg mounts and new rear float mounts.
Sent from my iPad using Tapatalk Pro
mtv wrote:m_moyle wrote:Question… aren’t external loads loads specifically allowed in Alaska without a field approval? Wouldn’t a cargo pod fall into that category just like a lumber rack… I’m thinking of building one for my PA20 using the original rear gear leg mounts and new rear float mounts.
I'm guessing here, but.....An external load, as defined in the Alaska Region policy on carriage of external loads on fixed wing aircraft is basically a "load" not an "installation".
It's pretty clear that a cargo pod is a piece of "installed equipment", not just a temporary "load".
Another example might be tires.....hang a set of monster mudders on there, and.....etc.
So, I'd definitely have a chat with the FSDO before I went too far down that rat hole. But, if it works, definitely let us know....
