Thanks to Big John and Courierguy for info on the kit.
BTV wrote:Sent Hal a deposit for a 1484 high power kit. If weather cooperates I will fly to Elko for the install before High Sierra Fly-in.![]()
BTV wrote:CG thanks for the tip. I will definitely pick some up and anything else Hal recommends.
I've been using the tempest filter. I wonder if it is any better than the Rotax. What is the Cat filter Hal recommends.
We had 3 S-7's parked outside, and two more in the hangar still under construction
courierguy wrote:Hal put the Prince prop on his bird right before he left for Blackfoot, then took it off. He will be sending it back to Lonnie to have the tips shaved in order to gain some RPM. He likes to see 5400 static, and he could only spin it up to 5160. I think most Rotax operators shoot for about 5200 static? I know I do, but Hal has very specific reasons why he does his way. I, with my low comp Zipper (Hal has the Hi comp) could only get 5,000, barely. Even at that low RPM, the Prince performed great on takeoff and climbout, and cruise. We are both at very similar altitude, around 5 K. The good thing is now Lonnie has even more information, so my shortly to be delivered prop should be pretty well dialed in. Still waiting on the second Catto, it'll get here when it get's here I'm told. These prop wizards need to do their thing in peace and not be hassled with phone calls and emails, thank God I have the still excellent Kiev prop in the meantime, so I can afford to be patient![]()
Speaking of Kiev, things are really heating up over there, Putin indirectly started this whole prop thing I'm now involved with, go figure, maybe the prop company is business as usual but hard to imagine how it could be and I want some prop alternatives.
Well I guess it's 641 now....as the 1484 is that much lighter. Joel said it held a 1500 FPM climb, not a zoom, but held it. 70 degrees or so and 4500' field elevation. He was real stoked about it, though he only had a few around the patch flights in it so far. I told him it will take a few hours to really get the subtle changes, like that mid range torque increase, and the instant response when hitting the throttle. Hal had some iffy weather in the AM, but made an end run around it, it almost looked like it was going to snow at my place! I flew another 4.6 hrs and got in another new 9600' landing today, so you know I am liking mine.
