Yesterday I flew a bit, when I came back and went to push the airplane back in the hangar I saw fuel dripping out of the bottom of the fuselage.
So I figured it's that good old Cessna valve leaking, and so I drain all the gas out of the tanks to prevent it from just leaking out (five (#$*% dollars and sixty-five mother ($#*$% cents a gallon).
So tonight, I'm under the airplane cleaning the crap off the belly, and removing inspection plates. I reach in and run my hand along one of the control cables, trying to develop a feel for where and how I'm gonna get the valve out without messing anything up.
As I'm running my fingers aft along that control cable (turned out to be the right rudder cable), my finger bumps into the fuel line. But it's still on the cable too. After a moment of "that's strange..." i look in with a flashlight to see the rudder cable entering the fuel line at a 90 degree angle. The cable is not under the fuel line, or even slightly embedded in the bottom of the fuel line, the cable has cut so far into the fuel line that the bottom of the cable is <edit FLUSH WITH> the bottom of the fuel line, <EDIT>.
After a few choice words, I looked a little closer to find that someone had routed the right rudder cable under the fuel line, rather than over it. (Or, they had the valve out and when they put in the fuel line they forgot to make sure the cable was above the fuel line) So every time I pushed the right rudder, the cable sawed slightly into the aluminum fuel line. But I've been flying this airplane for over a hundred hours since I bought it, and had never seen any significant leaks. How this cable sawed into the fuel line and never leaked before is beyond me.
I want to take some photos of this to share with everyone, before I take it apart. So tomorrow I will try to do that, and see if I can post the photos on this forum.
I am guessing the previous owner rebuilt the fuel valve, and when he put it back in he got one cable on the wrong side of the fuel line.
So next time you are doing an annual or have the airplane down for maintenance, please have a look through the belly inspection plates to see if someone made the same or similar mistake on your airplane !
gone .Rudder on AA1 has a set of "rudder return springs " that will pull rudder to floor and you snap roll and die --- Lets all get in and look at the control cables in whatever kind of airplane and see that there in proper function . Found a Positive battery cable (in Cessna 180) shorted out to airframe belly right below fuel control valve . A little bit of arcing and your done.
