River rat wrote:The Cessna 170B is one of the best planes ever built and lycoming 0-360s are one of the best engines around it's crazy not to put them together.
River Rat for the Win!!
-DP
denalipilot wrote:River rat wrote:The Cessna 170B is one of the best planes ever built and lycoming 0-360s are one of the best engines around it's crazy not to put them together.
River Rat for the Win!!![]()
-DP
Zzz wrote:Congrats, man. It'll be a sweet machine. What STC are you using and why did you decide to go injected?
robw56 wrote:Any idea what the weight difference is between an IO-360 and MT prop vs a O-300 and fixed pitch McCauley?
TomW wrote:DP,
Can't wait to hear how that IO works out for you in the 170. I've often thought that would be a nice final touch to the 0-360 conversion. I occasionally fly a Travel Air with parallel valve I0-360's. They run so nice!
I just installed the EI CGR 30 CP in my 170 (pretty sweet).
As far as weight goes, my Avcon conversion added 40 lbs. on the nose. If the CS prop wasn't all 40, I'd say it's probably 99%. I've since been replacing stuff with new lighter weight goddies. Last weight saver was a Sky-tech starter. The next will be replacing the Gill with an Odysey. Those two alone will lose half the conversion wt. gain. Your prop ought to be amazing.
Would love to see some pics of your project.
Tom
denalipilot wrote:robw56 wrote:Any idea what the weight difference is between an IO-360 and MT prop vs a O-300 and fixed pitch McCauley?
Not exactly, but I understand it's not that significant. The 2-blade MT saves about 30 lbs over the 2-blade aluminum Hartzell, which was definitely a factor in my prop selection.
L18C-95 wrote:I am guessing RoC with the new engine is 1,000fpm+?
Does range/ endurance suffer at all, or does the fuel injection and extra speed compensate?
