mtv wrote:......
7) Mixture set to idle cutoff, after you've primed the engine. If it tries to run off, it won't get far. As soon as it catches, push the mixture to full rich. Don't try this from out front....running past that spinning meat cleaver can be a career ending experience. Another argument for propping from behind.....
Not sure if this was directed at my own comments ("I've hand-propped a number of different airplanes over the years, but always with an experienced pilot at the controls." "He tied the tail to the corner of the hangar with some sort of slip knot, which he could untie from the cockpit."), but if so, I just haven't had the need to hand-prop by myself, that when I have hand-propped, I always had a qualified person at the controls; and I was just commenting on another pilot's method of doing it by himself. I've certainly seen others hand-prop without help. At one of my regular fly-ins, a frequent attender comes there in his Ryan PT 19, which he hand-props without help (sounds a lot like a John Deere tractor). A tenant at GXY hand props his Aeronca without help--I usually see him at the gas pumps. Neither of these guys ties their airplanes to anything, but the Aeronca pilot does chock his (every time? I don't know). As for propping from behind, I've never tried it, but I don't know why it wouldn't work. I also haven't tried hand-propping with the mixture-off, but I don't think my airplane's engine would run long enough for me to get back in and push it in--hate to admit it, but I have tried to start it with the starter without pushing in the mixture--it started but didn't run more than a second or two. I agree that every pilot should learn how to hand-prop an airplane, but I admit I'm happy not to have to do it regularly.mtv wrote:Sigh......
I get tired of hearing all the internet experts pontificating about how you always need a "qualified pilot" at the controls while hand propping, and/or the tail needs to be tied down, with some sort of magic knot......etc.
hotrod180 wrote:mtv wrote:......
A little different deal propping a Cub than a C180 or similar. You can leave a Cub door (or for that matter) a C182 jump door open for quick access to the throttle etc-- access is not so quicl or easy with other door styles. Esp with some prop wash helping hold the door shut.
I've tried to start engines with the mix pulled out- never ran long for me to get into the cabin and push it in before it woulda died.
I'm not sold on propping from behind, esp if the door is not of the fold-down or fold-up variety. If the engine roars to life and the airplane starts rolling, the wing strut (or wing itself, of a low wing airplane) and main wheels are trying to push you forward -- right into the prop. I'm much more comfortable propping from in front, stepping back as part of the follow-through from the downward swing of the prop.
Cary wrote:Not sure if this was directed at my own comments ("I've hand-propped a number of different airplanes over the years, but always with an experienced pilot at the controls." "He tied the tail to the corner of the hangar with some sort of slip knot, which he could untie from the cockpit."), but if so, I just haven't had the need to hand-prop by myself, that when I have hand-propped, I always had a qualified person at the controls; and I was just commenting on another pilot's method of doing it by himself.Carymtv wrote:Sigh......
mtv wrote: .....If your prop isn't indexed properly, get it properly indexed. Most engine/props should be indexed to come to rest at the 10:00 and 4:00 o'clock indexing, as viewed from the front. If your avatar photo is accurate (ie: not a mirror image) then your prop may be indexed wrong. Get it fixed, and it's a LOT easier to prop, from front or back.....
hotrod180 wrote:mtv wrote: .....If your prop isn't indexed properly, get it properly indexed. Most engine/props should be indexed to come to rest at the 10:00 and 4:00 o'clock indexing, as viewed from the front. If your avatar photo is accurate (ie: not a mirror image) then your prop may be indexed wrong. Get it fixed, and it's a LOT easier to prop, from front or back.....
You're assuming a lot. The prop is where it is (close to vertical) because that's where I rotate it to when I have the airplane in the hangar. Keeps me from having to duck around the prop every time I come through the (narrowly-opened) doors, or walk around the front of the airplane. I've only had the airplane about 5 weeks or so, and I have no idea if the prop is indexed where Cessna and/or TCM says to index it. Or even IF they do. But I think most indexing specs are done to compensate for vibration / harmonics issues, NOT to make it easy to prop ( at least on a starter-equipped airplane).
A person should prop in a matter that he's comfortable with. I asked my hangar neighbor buddy to prop me the other day when I ran the battery down, and he was man enough (no phoney macho BS) to admit that he hadn't done enough hand- propping to be comfortable doing it. That was fine with me-- I had him sit in the RH seat instead to man the brakes & ignition switch. I prop from in front because that's what I'M comfortable with, esp with this airplane. I was taught to start with my right leg up, then swing it down along with the prop as I step back away from the airplane. As safe as any method I've ever seen, and it has me moving away from the prop instead of leaning into it as it seems I would be doing if I was behind and between the prop and the RH main wheel/gear.
If you're more comfortable propping from behind, great. But don't knock others if they are more comfortable doing it differently. After all, there's more than one right way to skin a cat.
mtv wrote: Don't get your undies in a huge knot....
mtv wrote:And, propping from behind does NOT have you moving toward the propeller. The motion is all downward, not forward. Again, if anything goes weird, the prop is going away from you, not toward you.
Terry wrote:mtv wrote:And, propping from behind does NOT have you moving toward the propeller. The motion is all downward, not forward. Again, if anything goes weird, the prop is going away from you, not toward you.
Oh YESit does! If we are talking taildragger.
Propping from the front a taildragger will push you AWAYfrom the prop as you pull it through.
NOTso much on a nose gear as the prop is more plumb. I feel much more comfortable with a taildragger, but I'm no hand propping pro.
My 180 with 29's propping from the rear will DEFINITELYpull you forward as you swing it through.
I haven't tried propping from the rear, I'll try it next time.
Cheers
Terry wrote:My 180 with 29's propping from the rear will DEFINITELYpull you forward as you swing it through.
Cheers
