Wannabe:
What is the issue with this STC?
RGilland wrote:.... The mechanic told me the hole in the main gear for the stud on the axle is too tight of a tolerance to add the alignment shims. He is suggesting we get approval from the FAA and cut off the stud, or replace the axles with Cessna axles.....
RGilland wrote:.....Now my question is..... Should i still be concerned about this conversion?
Cary wrote:... he said to me, "If you want a tail dragger, buy a tail dragger. If you want a tricycle, buy a tricycle. But don't buy a tricycle that has been converted to a tail dragger--it's nothing but trouble." ...
bush master wrote:I have been around a number of these conversions and they were a good conversion for the money if done right. They use the original 172/175 hollow aluminum axle which were subject to breakage ( see 170 Faa service difficulty reports from a number of years ago ) this steel stud through the axle puts compression on the axle thus for all practical purposes eliminating axle breakage. ....
