G44 wrote:RockHopper wrote:If you can fly a Maule, you can fly a Wagon. In the air, its just another Cessna. The only issue is the touchdown itself. In the flare, setting the weight of the aircraft with minimal deflection of the gear is what takes some time to learn. Not difficult, but takes a bit of seat time to master. Otherwise as others have said, keep it going straight, and its pretty honest. I almost always use the tail low wheel landing any longer. I’ve seen too many cracks in the tail structure (hockey stick) that I believe is the result of hard three points.. I think in the past it has got a bad rap from people who didn’t check to make sure their gear was aligned. That can happen if the airplane is moved back and forth from wheels to floats often and the alignment check is overlooked.
Actually alignment issues have more to do with removing the axle's and not reinstalling the shims between the gear leg and axle correctly than float changes, although I guess that could be a contributor but in my experience it hasn't been. Those shims are tapered, each airplane is a bit different so if you ever remove your axles make darn sure you install the shims the exact way they came off (if the gear was properly shimmed in the first place). After you get it back together it is a good idea to put the airplane on grease plates or what ever your prefered method is and confirm wheel alignment. Proper wheel alignment is critical.
Also, NEVER tie an airplane down with chains!
What Kurt said. If, after some practice, the plane seems to have a mind of its own, get the thing on grease plates and check the gear alignment. A friend once called me and asked if I’d go fly with him in a Cessna he’d owned for a year. I asked why, and his response was he was scared to put his family in it. He did the first landing, and I don’t think I’ve ever seen anyone work so hard to land an airplane. So I did the next one.......yow!
We drove it over to his mechanic (who’d been blowing him off for months) and told him to put the thing on grease plates. After alignment, it was a sweetheart.
No mysteries to landing these things, really. Get used to the spring gear and you’ll do fine.
I most frequently use 30 flaps, but practice with full, and 20 as well.
Tail low wheel landings are or should be almost mandatory.
On landing and takeoff, don’t worry about keeping the centerline in the middle of the plane.....put the centerline between your feet......it’ll only be a foot off center, and easier to judge, and that’s good enough for me.
In training, line up for a full flap, trimmed, power off landing, and close to the touch, go around. Be prepared to PUSH really hard on that yoke. In that case, on short final, I keep some nose down trim in to help with stick forces in the event of a go around.
