I'm posting in hopes of folks punching holes in my idea, so feel encouraged to explain the errors of my thinking.
This may not be much a fun factor to others, but robust rate of climb is something I truly enjoy. I can't help but think the rate of climb of the Carbon Cub is a strong selling point for a new $200K Cub.
I know the Titan Tornado II isn't what anyone here would consider an acceptable back country plane, but from reading posts here I value this forum membership's expertise.
OK, here is my idea for a rate of climb hot rod. With an empty weight of 440 lbs, MTOW of 1000 lbs, and popular engine option of the Jab 3300 @ 130 hp, it does a very respectable 2000 fpm. The 3300 weighs 184 lbs ramp, but since it is a pusher, a increase in weight has a smaller influence on CG than a tractor. I would like to try the new UL Power UL 520iS. I'm a big fan of EFI, and the ramp weight of this engine is 238 lbs, just 54 lbs more. At 200 hp @ 3200, my guess would put it 2700 fpm. I would still want it E-SLA, so if a climb pitch prop was used to limit speed to 120 kt, would this still be SLA compliant in the same way the Carbon Cub is with the throttle placard giving max rpm at different altitudes? Does anyone know if the Titan II has enough tail feathers and moment-arm leverage to deal with the added 70 hp? Don't write me off as crazy, I have 525 hp in a 1790 lb roadster and admit being a immature power to weight junkie.
