Backcountry Pilot • Cessna 140 Sportsman STOL
29 postsPage 2 of 21, 2
Re: Cessna 140 Sportsman STOL
glacier offline
glacier wrote:What are the downsides to a sportsman? Cost, weight and thats about it? I'd loved to have had it on my 140.
I had a good feel for when the airfoil gave up, and with nose high power on landings it would give up all at once. Compared to a sportsman equipped wing, it feels like playing with fire if you really stall it on. Take off not so much, things don't really happen all that fast anyway, and just keep it in ground effect until its really flying. Same idea as any other plane really.
For take off the mac 75/35 sea plane prop really helped the O-200. Static 2600 rpm, redline pretty quick on T/O. I always took off with full flaps, either set at the start of the roll (heavy) or I'd pop them (light). I was considering adding the trailing edge bulb to the flaps just to make them a little longer.
But I do think landings benefit from the gentle stall of the Sportsman, just give a nicer margin. Landing shorter than you can take off, sure, thats pretty normal. And it is a pretty tight gnarly spot that doesn't offer up more space once you're on the ground and can get out and look around.
How on earth did you get a 75/35 prop approved on an O200 powered 140? I thought the O200 was limited to 69 inch props? I may or may not know of a particular 140 with a 71/45 prop :wink: but I cant find any approval for it.... how did your 140 perform with that prop?
jlacharite offline
Aircraft: Cessna 140 N89476
Cessna 170B N2693D
glacier offline
For the Mac 1A90CF 7535 you might try having the pitch confirmed and maybe adding a couple of inches. If you're running an accurate static of 2600 (as measured with an electronic tach or outboard tach checker) then dropping to 2500 would still provide good takeoff but prevent over revving and offer better cruise. I've used them in both 35 and 38 pitch and that seems to be the range that works.
Did the O-200 approval come with rpm or horsepower limits?
Gary
PA1195 offline
glacier offline
Were there any rpm and HP limitations for the O-200 installed on the C-140?
The cam profile of the O-200 is built for a C-150 and short prop. The C-90 has the same displacement and compression but a cam designed for torque at lower rpm. The C-85 cam has the same timing but lower valve lift.
All about trying to get power plus airspeed out of a small light engine which is ok but not a STOL setup unless in a light STOL airframe.
Gary
PA1195 offline
glacier offline
robw56 wrote:
Hammer wrote:Since a 140 will already land shorter than it will take-off, and take-off and climb are dependent on excess thrust, not excess lift, I'm curious whether the mod would really be of any value, even if you could do it.
Everyone says the same thing about a Cessna 170. The Sportsman STOL kit was the best thing I did to my old 170 and I’d do it again.
+1
I purchased a well cared for 170B two years ago, incorporated some of the more "desired" options, STOL, VG's and have enjoyed the performance associated. I'd recommend doing so to anyone else, not that there's anything wrong with the a "stock" 170B they are a fine airplane. As new performance enhancements arrive they bring new life, new options and new adventures. If it opens up a new adventure or two for you enjoy, play safe and report back often on the experiences enjoyed
