180Marty wrote:Brian, that's kind of interesting that the tail on the 185 would be so loose after just 600 hrs.
BazzLow wrote:Last day put the tail back together and re-rig properly. (1-2 days)
Halestorm wrote:BazzLow wrote:Last day put the tail back together and re-rig properly. (1-2 days)
If you install Aeropod’s inspection panels back there you can seriously speed up the assembly and rigging process of a Cessna 180/185 tail.
lefoy84 wrote:Amen!Halestorm wrote:BazzLow wrote:Last day put the tail back together and re-rig properly. (1-2 days)
Norcal64d wrote:Question for you gents. I am looking at a '53 C-180 for sale and while the jackscrew was replaced in 2017, I don't see anything in the work order about complying with SEL-55-01. They elected to replace the jackscrew after an off airport landing resulted in damage to a wing tip, landing gear, and a dent to the leading edge of the horizontal stab. Because the jackscrew was fairly sloppy before, they elected to replace it in the insurance claim. My question would be how invasive should the pre-buy be? Pull the covers and borescope? Or does some real dissembly need to occur? Or, should the pre-buy also include full compliance?
Brian-StevesAircraft wrote:….Just had the tail off a 185 recently to address some serious looseness in the horizontal stab... Turned out to be worn out hinge bushings... Bought a whole set from F. Atlee Dodge for just over $230....
Pinecone wrote:Steve Knopp at Pponk has approved nylon bushings to replace the needle bearings. He developed them years ago to help coastal operators who were having trouble with corrosion in the needle bearings.
AEROPOD wrote:lefoy84 wrote:Amen!Halestorm wrote:BazzLow wrote:Last day put the tail back together and re-rig properly. (1-2 days)
Thanks for the plug guys!
It does make installing and removing the vertical a one man job if you're careful.
akaviator wrote:AEROPOD wrote:lefoy84 wrote:Amen!Halestorm wrote:[quote="BazzLow"]Last day put the tail back together and re-rig properly. (1-2 days)
