Bagarre wrote:How would a 195 compare to a 170 for ground handling (visibility aside)? Or is it apples and oranges?
I'm thinking about a 195 for a while now that my 170 is sold.
Is it an insane thing to consider a 195 as a club plane between 4 or 5 pilots?
I suppose if you got the right 4-5 pilots together, it might work, but probably not. I owned a C-170B for a number
of years, then my '54 C-180 for a number of years, and now I have the '52 C-195. There is a reason Cessna quit
building round engine airplanes and went to the more "user-friendly" horizontally-opposed engines... Less
maintenance, less things to worry about (hydraulic lock) before you start one up, etc. You don't see C-170/180 guys pulling
the prop through before engine start, or parking the #1 prop blade on the #4 cylinder @ TDC after each shut-down,
etc. Ground handling in the 195 is not unmanageable, but it is "different" than the 170 or 180. There is *way* more weight
on the tail wheel, and the tail wheel is at least a foot and a half further back. You don't do anything fast on the
ground in the 195... Plus you can't see *anything* out the right side when you're taxiing it by yourself (I put a small
WiFi camera near the RH air vent that is blue-toothed to my iPad so I can see over the RH side of the nose when I
am taxiing it by myself).
Per my previous comments, there are some peculiarities about the 195 that can even cause issues for guys with 20,000
hours who have flown all other kinds of taildraggers before (more than one 195 has been wrecked / ground-looped shortly
after purchase and/or during "checkouts" by high-time airline pilots who have flown all other kinds of taildraggers). I know
of one that was ground-looped by an airline pilot on the way home from the purchase, that project was sold to another
guy who rebuilt it and had another high-time airline pilot "test fly" it, and it was promptly wrecked / ground-looped again!
Unless all 4-5 club members are proficient & current in larger/heavy taildraggers, and in particular, proficient & current
in the 195, I am thinking a 195 in a club environment is a ground-loop accident waiting to happen... There is a group of
guys in California who own a number of airplanes in a club environment, and they had a C-190 in the club for awhile, but
they traded it away (I understand only 1 or 2 club members were able to get checked out in it).
