Still works fine for me.SkylaneSam wrote:Hummm. The link is taken down.
205Pilot did you do that intentionally or did YouTube do that?
Mapleflt wrote:I suspect a representitive of the FAA will soon be knocking on your door to discuss the details, regulatory actions under consideration, corrective measures. They will most definetely carry out a full investigation of the events. In the final analysis they will clearly be requesting your YouTube video as evidence for their "how to" library, WELL DONE SIR
PapernScissors wrote:Mapleflt wrote:I suspect a representitive of the FAA will soon be knocking on your door to discuss the details, regulatory actions under consideration, corrective measures. They will most definetely carry out a full investigation of the events. In the final analysis they will clearly be requesting your YouTube video as evidence for their "how to" library, WELL DONE SIR
Doubt it. A catastrophic engine failure is not a reportable accident unless there are fatalities, serious injuries, and/or $25 K in damage (which doesn't include engines, accesories, or props.
Dog is my Copilot wrote:I am curious just how common a catastrophic engine failure due to a mechanical failure occurs. It is a little bit off topic and I could move it to a different thread if needed. I am curious how often this occurs per hours flown. Most engine failures are due to pilot error related to fuel starvation/exhaustion or carburetor ice. I have heard the catastrophic failure occurs about once in every 5000 hours of operation with large bore Lycomings/Continentals. Does anyone happen to know the answer to this question and where the data was obtained ? Seems we fly various missions with different risk profiles and knowing how common this type of failure occurs would be important.
Josh
NTSB annually publishes 'defining events' (aka 'root causes') for prior years. "SYSTEM MALFUNCTION: POWERPLANT" is a separate categoy from "FUEL". FWIW, my read of the category is that all (100%) of "SYSTEM MALFUNCTION: POWERPLANT are either mechanical (the vast majority) or pilot screwups. Another FWIW: loss of power because the engine quit is ALWAYS (every year!) ranked in the top 3 'Defining Events'. Fuel issues (both starvation and exhaustion) are far fewer than mechanical engine problems. FWIW (3) engine failures, fuel issues, whatever aren't counter or REPORTED anywhere unless there's an accident reportable to the NTSB or the FAA finds some inconvenience to a lot of people and tracks it as an 'incident'.
Dog is my Copilot wrote:Handicapping the true risk of a mechanical failure is difficult. I try to be in a position to glide safely in most phase of my flying but some of the backcountry/mountain flying it is just not possible. Good to practice power off procedures and mitigate as much risk of possible. Being in the right place at the right time is not always lucky. Having a Garmin Inreach, BAS seat belts, and having some survival gear also important too. Nice job with the bringing the 205 in safely.
Josh
