Conti 0-300: The Real Deal
Sun Mar 21, 2021 12:11 pm
Can anyone in the community offer their opinion or better yet operational experience with this product, please & thank you in advance.
https://realgaskets.com/product/pushrod-tube-seal-kit/
2382
Sun Mar 21, 2021 12:41 pm
I dont have operational experience, but I would like to try these out. I feel like they should work great, and it is a lot of work to re-seat the original push rod tubes, and even more work to replace the old push rib base seals.
5218
- Aircraft: Cessna 210J, Citabria 7GCBC, AT402/502/602
Sun Mar 21, 2021 12:57 pm
The Real Gasket pushrod tubes work fantastic. The stock rubbers and clamps are f*^%ing horrible. Continental makes a version too.
You don't have to remove cylinders to install them. Take the rocker covers off, remove the rocker shafts, rockers, and pushrods. Cut the rubbers at the base of the pushrod and remove everything by prying it out of the rocker box.
Buy the spring compressor tool. If you have problems, Chris at Real Gaskets is a "real" good dude. Yes I'm biased and have probably sold 1 sets of these for him on O-300's and O-200's.
Aryana offline
936
- Aircraft: 1955 Cessna 170
Aryana offline
936
DuPont overhaul pictured above.
Aryana offline
936
2382
Aryana wrote:
It almost seems a shame to hide this from the world under an engine cowling, it's a "work of art" sir
2382
Sun Mar 21, 2021 10:24 pm
I have installed these on a couple engines now... not hard to do and they actually seal the oil from leaking out the tubes unlike the stock junk... not too expensive either..
Brian
Brian-StevesAircraft offline
761
You're too kind...thank you.
Aryana offline
936
I'm about to get going on a top overhaul before switching to floats for the summer so the timing is perfect for incorporating this "upgrade".
2382
My Continental cylinders with the upgraded pushrod tubes have worked out really well. Installed in 2014 and have not leaked a drop of oil.
Waterboy offline
288
- FindMeSpot URL: http://share.findmespot.com/shared/face ... sosgK4n7cI
This is the way they should have been built from the beginning.
Aryana offline
936
Wed Mar 24, 2021 12:59 pm
Aryana; which jugs are those, Millennium?
2382
Mine are Continental cylinders that were overhauled by One Stop Aviation in Oceanside, CA.
Aryana offline
936
Thanks, I’ll reach out to Real Gasket to confirm compatibility with the Millennium jugs fingers crossed they play nice in the sandbox together.
2382
I have them on my Milliniums. Much better than the originals.
jugheadF15 offline
309
I've had the Continental cylinders on a customers 170B, we were in the process of installing the Real Gasket kit on his engine, but found a shatter cam follower, so we went all in when we overhauled it. Have Millennium and ECI cylinder on our 172. Probably going to try to go Real Gaskets soon to fix some of the seeps.
WorkingWarbirds offline
92
- Aircraft: Champion 7GCBC
Mooney M20E
Globe Swift
The Real Gasket pushrods will work on Millennium or Continental cylinders. They just slide into the empty pushrod tube holes in the rocker box once the original tubes are pried off.
Aryana offline
936
I’ve put a few of these on before and I had trouble when I installed them on my engine, the # 1 cylinder exhaust is rubbing on the pushrod tube. I have
Millennium cylinders with thick flanges on the exhaust stack
richw56 offline
124
- Aircraft: Cessna 120 125 Lyc.
I’ve put a bunch on small cont and they work great
Tom offline
793
- Aircraft: PA-18, C-180
