Hole Guacamole!! What a lot of advice. Mostly useful, mostly accurate, and it sounds like Mr. JC has a good attitude about the whole thing.
I DO NOT advocate the Crab to a slip kind of approach, even in a tri-gear airplane. There's just too much going on at the very last second: Judge your height, flare when appropriate, hold it straight, and oh, yeah--try to transition to that perfect wing low attitude which will control the drift, WITH NO PRACTICE on final.
I like to put the wing low on 1/2 mile final, and hold it there.
Oh, yeah--I'd also point out that there is ABSOLUTELY NO DIFFERENCE in proper technique to approach in a crosswind in a tri gear airplane compared to a tailwheel airplane. It just has to be more precise in a taildragger.
Here are a couple things that seem to buffalo new pilots in this regard:
The earth's interaction with the wind creates some friction. This changes the wind direction AND velocity between a few hundred feet and the surface. The same control inputs WILL NOT work in the flare as worked at 200 feet.
To make this even more significant, as someone mentioned earlier, as you slow the airplane, it will take larger control inputs to accomplish the same aerodynamic result.
In other words, the control inputs you have to use ARE VERY DYNAMIC. FLY THE AIRPLANE, and use the control inputs required to make it do what you want it to do.
Here are the three requirements for a good crosswind approach in a nutshell
1) You MUST be ON the extended runway centerline. Look at the FAR end of the runway, and use some reference on the airplane as a "gun sight" to help you align PERFECTLY with the centerline. If you aren't PERFECTLY aligned with the extended centerline on 1/4 mile final--go around. It doesn't hurt to put a grease pencil mark on the windshield in front of you as a reference point to align with. This task is accomplished with a wing low, induced by aileron input.
2) The airplane's lengthwise axis MUST be aligned with the centerline of the runway. This is accomplished with RUDDER, after you've got the side drift controlled as above.
3) The airplane MUST be GOING the direction it's lengthwise axis is POINTED.
Focus on those things as you cruise down final, and keep your vision waaaaaayyyyyy off in the distance, the far end of the runway or FURTHER, and as long as everything is as above, flare at your normal height, and DO NOT change all those control inputs you have in.
The biggest error I see with students is that as soon as they start the flare, they neutralize all the controls. You will then start to drift, and induce side loads.
Have fun--it is not rocket science. THis is perhaps the single hardest maneuver to master when learning to fly. Be patient, and it'll come.
