Cutting the carbs
Does anyone within the community have experience with the Rotec TBI fuel system, extra points if it's the one for the 0-360.
2387
Thu Apr 02, 2026 11:52 am
I'm gonna throw this question out to the BCP community again........
Does anyone within the community have experience with the Rotec TBI fuel system, extra points for Lycoming 0-360 specific intel
2387
I had one on a Rotec 9 cylinder radial. I sold the project about the time it was ready for a DAR.
In dealing with Rotec on the engine and some related parts, I’d say I was grossly unimpressed. I think I probably saved my life by not finishing the project.
You probably know, but it is NOT fuel injection. It has a Venturi with a “spray bar” in it. Vacuum through the Venturi sucks furl from the spray bar. It’s quite simple, and may work, but the more I worked with Rotec, the less confidence I had in their products.
StillLearning offline
474
- Aircraft: Cessna 180 Skywagon 1953
I appreciate the input, thank you.
As you point out it's not an injection system, it's very simple in design which is a large part of the appeal for me. I had a couple of occasions to chat with Rotec but the questions where were generic in nature not about product support so I will take that into consideration. The model recommended for the 0-360 does not required power to operated, that's also part of the appeal but apparently will output fuel flow by some means.
Thank again for your observations, cheers
2387
