Just fly whatever you have to match the performance charts published for that aircraft and you'll be fine. If you ignore those you'll get into trouble with anything you fly. If you are asking what aircraft can I fly heavy and hot, outside the performance charts, ignoring the terrain, using less than optimal technique, and still be ok, then try pick something with a high lift wing and more horsepower than it needs for its official gross weight. Super Cub, Citabria GCBC, deHavilland Beaver, Twin-Otter (or even a single with the turbine conversion). But the plane on its own won't save you from yourself.
I'd hoped the Stinson guy would have leaned for extra engine performance on the takeoff, and nailed the climb speed to within one knot. I didn't really see anywhere in the takeoff where I would have chanced a 180 degree turn. Straight ahead into the trees at that point with everyone still alive is better than a lawn dart partway through a turn.
