Blu wrote:I guess i was thinking that in the video stol preformace wasn't the issue. The runway was plenty long and he got in the air.
What i was thinking is that a Stitson is a better backcountry/STOL plane than say A36 bonaza. I say this because if i was going into a strip like "mile high" or "vines" with 1/2 fuel and a just me on a cool day the stitson is by far my first choice.
But in the situation we see in the video the stitson was taking off at close to its service ceiling leaving little to no room to climb, while i would submit that the BO would still have at least a few thousand feet of climb left in it and with almost a mile of runway there was ample room to get it off the ground and the wheels up while in ground effect.
I guess im just arguing that a good "back country plane" and a good "high country plane" is not always the same thing when there is plenty of runway.
I have an S35 Bonanza, a few hundred pounds lighter than an A36 but the same wing and engine. I don't know the weights of the folks in the Stinson so I'll just use my plane at gross weight of 3300 pounds, far more than the Stinson could ever hope to be. Using the conditions of that day and assuming no wind my plane gets off the ground in 1500 feet and then climbs at 800 feet per minute per the POH.
Assuming 4 FAA standard folks for 680 pounds and a half tank of gas I would be 350 pounds under gross. Takeoff roll now 1300 feet and rate of climb 1100 FPM. Those are book values, I have VGs so would be slightly better.
Any Bonanza is far superior to a Stinson for that mission. As for what's the better plane the question is what's your mission? I sold my 182 7 years ago for my Bo and have taken it everywhere I ever took the 182. For a typical camping mission the 182 needs a couple hundred less feet for takeoff or landing but then gets smoked in climb and cruise and will use more gas than the Bo. That can be offset if you can use car gas, although the older Bo's can use that too.
