Timberwolf wrote:The original Rebel design has them as full length flaperons. They look independent until you realize they are connected in the center of the wing and both move together. With the Elite came the ability to split them into flaps and ailerons. A feature that can be added onto any normal rebel as well. I have the flaperons and prefer it. This is the only area of the whole Rebel design I would change. There is quite a bit of play in the way the whole system works. It does work good, but I hate to have play and know that some parts are flexing in the system due to the load imposed in flight.
It sounds a lot like the flaperon system that was installed on the Victa Airtourer (old military training aircraft in the Australasian region). They get really sloppy by the time they are worn out.
There is a Super Rebel 2500 which I see at a lot of our regular AOPA fly-in events, I haven't flown in it yet but I've had a darn good look around it, worked all the controls etc. I recall they did have flaperons on the Super Rebel, but this one's owner didn't care for them and had disabled them. I think maybe he talked about free-play in the system, or perhaps it was control forces or stall characteristics. I can't recall.
I am pretty impressed with the aircraft itself, and apart from the gear I would certainly have one if I truly needed a 6 seater.
Of course they are like a C185 in many ways (apart from their design), I mean they are more like a C185 than a Bearhawk / Maule - they are larger, heavier, and need more room to take off compared to a pure-play 4 place STOL machine. But not a lot more room / weight. Very similar to a C185 in terms of their ability to fill a role.
The Moose is of course bigger and stronger again, and I assume it's somewhere in between a C815 and a Beaver.
