Drooped ailerons c180
Hi all,
Looking at a 180 and noticed that both ailerons are misaligned with the wingtip. Both are around 1” lower than the wingtip.
What’s strange is that they’re both perfectly aligned with the flaps however.
Is this a washout issue?
Thanks
- IMG_2747.jpeg (763.66 KiB) Viewed 1054 times
- IMG_2746.jpeg (1.1 MiB) Viewed 1054 times
Lettucelord offline
24
- Aircraft: C180
Does it have a Robertson STOL kit installed ?
2324
Have the wings been reskinned at some time or another (new tanks/damage)? Any major accident history? Due to it being both sides and they line up with the flaps could it be the wingtip tail that is high? Are the tips original to the plane?
DENNY
DENNY offline
773
DENNY
I bet the ailerons were reskinned at some point and the sweep at the tip was set wrong.
185er offline
72
- Aircraft: Cessna 185
Lettucelord offline
24
- Aircraft: C180
We were told no damage history but found a log entry for repairs to the wingtip, leading edge and aileron with 337.
However that was just for one side yet the droop is in both.
Lettucelord offline
24
- Aircraft: C180
She’s ether a Robertson and you got flaps down too
Or her APIA was Steve wonder lol
- Retired
1679
DENNY wrote: Are the tips original to the plane?
This is my guess. Wacky tips.
2854
Might be worth a call to Scott Mauch at Beegles in Greeley CO.
185Midwest offline
437
- Aircraft: C-185
Pretty easy to check if the flaps are too far down, it would have to be quite a bit out of whack to look like that.
StillLearning offline
417
- Aircraft: Cessna 180 Skywagon 1953
