As in most aviation ideas, "it depends" It gets complicated rather quickly. Let's take some examples:
1 A tailwheel aircraft makes a full stall landing on pavement with full flaps in calm wind. It's true there is very little lift being created, and the speed slows rapidly, and it really is a toss-up whether the roll will be shortened by dumping the flaps. The loss of aerodynamic drag about cancels the increased brakeing effectiveness.
2 Same aircraft, but now just a tail low landing. Aircraft will tend to skip or even bounce. Much more lift is still being created because the wing is not fully stalled.
IF you wait until the plane is back on the ground and dump the flaps to zero, the airplane will most likely stay on the ground and allow heavier brakeing without locking tires. Picking up the tail a foot or so will make the brakes even more effective. DON"T OVER DO IT! This is in effect a wheel landing.
Every aircraft will react to these scenarios differently. In a light two place with small and not overly effective flaps, it will make little difference. In a heavy taildragger like a 185 with huge flaps, it makes quite a difference, primarily because getting all the weight on the mains allows very heavy brakeing.
If you have electric flaps and a nose wheel, forget it, because the aircraft will have slowed to a fast taxi by the time the system gets the flaps to zero. With a slow electric system retracting the flaps is about the WORST thing you can do in a short field landing because the lift will actually INCREASE as the flaps go through 20 degrees at the worst possible time in the roll-out.
Losing control of the airplane is in fact a big issue depending on the layout of the flap handle. If I am landing in a gusty crosswind I will NEVER dump the flaps because I have to let go of the throttle to do so. I just use 20 or 30 degrees instead of 40 for a little more aileron and elevator authority and concentrate on keeping her straight. I may need that throttle at the exact instant that my hand has moved to the flap handle.
As a general rule, flap dumping is of little benefit for most pilots and most airplanes. Even in heavy taildraggers with big flaps it will achieve only about 10 % less ground roll over a properly executed full stall landing. It can be VERY useful however in a slightly hotter than normal wheel landing or with not so great surfaces like wet grass. Getting ALL the weight on the mains at the beginning of the ground roll for heavy brakeing will help a lot in this kind of situation. I admit I use the technique a lot in the backcountry, but I have over 1500 hours in my 180, and I have new Clevelands and new tires and can get really good brakeing when I need it. If I don't really need to stop short I generally don't use the technique.
I'm sure other members will have different ideas, this one is good for a lot of hangar flying.
Rocky
